Missfire Boost@4500-5500 RPM - The Answer! (for me at least!)
  • 7 months later...
Taping trick worked perfectly for me!
After finally finding the factory hose with restrictor in it for 7psi, once the car was hitting 7psi, was having massive amounts of missfire which wasn't there under lower boost. Pulled the coils out, clear arcing signs on the side of the coil (no cracks though). Gave them a tape up, and now it happily pulls right through!
Hopefully it lasts!
  • 2 months later...
  • 5 months later...
  • 7 months later...
  • 2 months later...
Had a thought today, instead of taping the coils up has anyone tried plastidipping them?
I think they originally designed it as a insulation coating for tools, and it seems pretty heat resistant so I'm sure it would work
It seems the tape doesn't stick well over time, and the ability to layer up the plastidip to get a thick coating means it should be pretty durable?
  • 4 months later...
Don't forget you can always use heat shrink down the "shaft" to the plug,
and/OR make up a set of Acetal coil plates - can't give this mod enough praise!!
I had a problem with misfiring but ONLY under full boost, 24psi, (12psi was fine)
turned out my coil packs were shorting to earth so I made up some Acetal
mounting plates and the miss is GONE, car has never run smoother!!
I got the idea from an overseas forum where this fix was solving heaps of problems for people.
I was actually thinking of making some more up If people might be interested in purchasing them?
Edited by 85URE
  • Like 1
Guess that depends on each persons situation, both financially and physically.
Every coil pack breaks down over time, at this point in time my problem was the coil packs earthing out,
By installing the plates, at a quarter of the cost vs new packs, it did remove my problem.
also allowing better cooling for the packs as the alloy brackets transfer more heat that is responsible for destroying them.
  • 2 years later...
Wher is it that you guys tape up? I recently got new coils but stil habe this problem, have tried everything that i can think of and have found online abut the peoblem exept silicon/taping the cpims (because they are brand new)
  • Like 1
    • Why are people so insistent on making dirty water?!
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
