At the end of day mate it is personal preference and or budget.Ive been thru 3 dif big name brands over the years.I had a cusco 1.5way (tight as) in my old 180 when i got it then when that went i put in a nismo 2way i got 4 a gr8 price and that was fine and not much noisier at all then the cusco (when u go in2 shop,carparks etc u just clutch it if u dnt want attention an the associated noise frm lsds).I now have a kaaz 2way in my 32 and its fine and doesnt really clunk or make that much noise,tho i have heard of sum lsds 1st hand that sound farked but dunno wat they r..if u keep the maintenence up on em n oil etc they can last a long time..
Hey man
Thanks for the information. Hopefully this diff will be fine and i will get use to the "Style" of driving as some people say has to change.
With the diff what oil do you use? I was thinking of using a motul around the 80w-140.
Cheers
Edited by niran
  • 2 months later...
Another option is to put a GTR rear end in, roughly the same price as a center but you get the larger axles/half shafts, I did this in my GTS-T R33 and Im very happy with the results, you cannot notice the difference of it on the street to the stock one (no cluncks or skids on tight corners) but on the track it hooks up well and is very predictable.
+1, that's what I have in my track car :( We shimmed it up, so it's tighter :D
  • 6 years later...
Resurrecting  an old thread, I believe there are different settings you can use with the Nismo 2-way and  I was wondering if anyone has a Nismo 2-way LSD in their car on the softest setting.
When I bought my car I had some old paperwork and one from Advan Performance back in 2009 stating the car had a Nismo 2-way LSD, I know most the other parts are there as you could see them.
But there is no clunking or any other noises and drives great in any conditions and slow speed ?
Is there any way to tell without pulling the diff apart ?
The Nismo GT Lsd is not adjustable, however the GT Lsd Pro is. Both are available in 1.5 and 2-way.
If you have no clunking or skipping around tight bends especially when cold I'd say it's unlikely that you have a mechanical diff ;)
5 hours ago, Nismo 3.2ish said:
thanks for your info, I will see if my mechanic up here and check it out, it is annoying having paper work that says there is a Nismo 2-way LSD and everything points to it not being a 2-way :(
Jack up the rear and try the spin test first (simplified, I hope I get this right) – with gearbox in neutral:
  • Spin left wheel one way and the right wheel rotates the opposite way -> open diff or VLSD
  • Spin left wheel one way and the right wheel rotates the same way -> locked/mechanical LSD
Some more info on diff identification: http://www.240sx.org/faq/articles/limited_slip_differential.htm
Thanks mate, I have the car going in to change all of the bushes and have new rear camber arms fitted, While its up I will get the mechanic to do it with me.
  • Like 1
    • Hello First, I apologize if this is not the correct forum. Let me know and I will move it to the correct one. I'm having a problem with the tachometer on my Skyline R33 with an RB25DET Neo engine. I'll tell you from the beginning. I'll tell you from the beginning. I have the RB25DET Neo engine installed in a Nissan Patrol GU, with a Link G4X control unit specifically for that engine,  and I have fitted a Skyline R33 tachograph to the original GU dashboard, but it doesn't work properly. I have the tachometer connected to the positive and negative terminals of the GU panel's wiring, and the signal cable is connected directly to the ECU output pin, but the rpm fluctuates widely. Can anyone tell me if the output signal from an R33 ECU is the same as the output signal from an R34 ECU, or if the voltage and signal type are different? Regards and thanks.
    • I guess it was the thought about "Oh if I were to drive this everyday". Then no, SL500 I wouldn't really consider lmao.
    • Yeah actually really fair point. Idk what I was thinking when looking at the SL500. Now that I think about it, I feel like I would have more enjoyment out of a shitbox that I would need to repair than some fancy merc. Although I must admit the SL500 does look quite nice. My bad hahaha.
    • 100% Also "Not wanting to spend money" is THE WORST IDEA IMAGINABLE when coming to a project car of any kind. They EXIST to BURN MONEY. Sure, gas money is a thing. A stock car with the worst fuel economy ever sold would probably be cheaper than modifying a car with FREE petrol for the life of your ownership of it, lol.
    • Amount of time you're being observed by law enforcement is so minute, that you could be a dumb shit 90% of your driving time, and never lose a demerit. You could also be the best driver ever and still get hit with a fine.   When you realise how quickly everything turns from "Wee, we're having fun!" To "oh f**k oh f**k oh f**k", you start to realise the only way to be a good driver, is to not be doing anything dumb or unexpected by normies on the road. You want to go fast, go to the track. Someone there in a 1990s slow POS will also show you how bad of a driver you are as they lap 10 seconds per lap quicker than you can in a car that should be considerably faster.
