  • Replies 166
Posted Images
Thought I might Bump this up a bit - Coming up SOON!
details earlier in the thread- but a recap-
Hope to see you there!
Date will be the 2nd April from about 5pm onwards. 1 Chaplin drive, lane cove west.
There is one major rule for this meet. If you drive like a fwit around or within the facility I will take your number and give the good old boys in blue a call!....this building is owned by my family and we do have use of it while we act normally.
Edited by PN-Mad
Can't wait! Who's bringing cameras?
Just a meet-up. It's a good location where we can sit back undisturbed, have a chat, talk and compare cars, have a feed, etc. It's in an industrial area, so there's not really that many roads worth cruising on.
whats the go with this..... just a meet up or a cruize aswell ?
PM me info plz :)
a cruise after is fine....I'm not organising though....could be organised on the night though.
Detail of the address and time have already been posted.
just bumping this thread with a reminder.
Date will be the 2nd from about 5pm onwards. 1 Chaplin drive, lane cove west.
Edited by Jetwreck
anyone coming from western sydney / blue mountains area that wants to meet up to drive to lane cove???
also i dont have an E-tag so the M7-M2 isnt really an option, pain in the arse i know (unless i can twist my bosses arm and use the one from work).
PM me for a meet up :thumbsup:
Wagonboy I'm coming from banksown area if you want to meet up.
The only sensible meet up would be around North Strathfield ??? and go through Five Dock / Drummoyne, but thats if we come down Parramatta Rd and not the M2..............
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
