Here are some results from a Wellington workshop:
A basic example of somthing we have tested at work.
RB30DET, usual standard mods, GT3582R. with a .63 on 14psi it made 300kw. with a .82 it made 330kw, though boost came on 500rpm later.
On 18psi the .63 made 350kw, where as the .82 made 375kw (could have made more but the power was more then enough for a street car)
The owner with the .82 exhuast housing, is looking to down size as the car isn't as responcive as he would like 4000rpm full boost.
Yeah true for 25kw I would prob prefer 500rpm of response.
lil update:
got spool rods
mahle pistons to suit rb30det builds -86.5mm
twin plate clutch
bosch 044 setup for in-tank
waiting on machine shop before i buy bearings incase i need to oversize etc
i went to a few tuners in perth they all said will make 500rwhp BUT i only have 555cc injectors which they all say i'll need to bigger AND so much contraversy about the 1.06, 1 bloke tells me to keep it one says go .63 another .82! haha so conflicting
Edited by Char
trying get this done before perth powercruise! (2 months!) so yeah, hopefully the 555s will hold up, dont really have time/cbf changing injectors
ovaboost suggested .63 hes running twin gt3540's in his 2jz LJ torana both with .63 making something like 800rwhp?
ovaboost are gonna be tuning it, thing is he doesnt like to run past 20psi boost (on pump fuel)
-going to go hunt the dyno section now for gt3540s 1.06 :D
-going to go hunt the dyno section now for gt3540s 1.06 :huh:
sure in a twin setup you could use the 0.63 but for a single setup stick with the 0.82 or the 1.06 (the 1.06 should make more power at lower boost from memory, though its ~400-500rpm more lag than a 0.82 so expect it to be on ~20psi at around 4000rpm with a good setup)
Who is doing the machining? I'm not holding my breath for the 32 to be ready for Powercruise so making sure the wagoon is skid worthy :D
nice!
its going in this week to hitech cylinder heads acid batch bore-hone- balance etc regular bits n pieces,
gonna strip the head also- not sure which one i'll use series 1 or series 2
ALSO the bloke wants to use an rb30 cometic head gasket
see how it goes
nice!
see how it goes
just make sure you keep a close eye on the price, i used the same bloke to weld the vct feed on my 25 head and he changed his quote 3 times. also ignore anything he says about compression
  • 4 weeks later...
evening,
i heard been working my through the rb30 thread so know basically what im looking at, just want some ppl in the know ie-YOU to give me some advice/opinions on my current plans :D
microtech lt10's, garrett gt3540 1.06r, turbosmart 38mm gate-screamer, 555cc's, 040 intake pump, rb25 box, greddy ebc, etc etc the regular supporting mods.
im hoping for atleast 450rwhp
any advice would be great
head:
stock. with internal mod.
im undecided which rb25det head to use as i currently have 3 in my posession, 2 series 1 heads and 1 series 2.
plans so far for the Block:
-Mahle forged rb30det pistons with rings n pins
need help deciding between either 86.5mm (20thou) or 87mm (40thou)
my machinist recommends the 87mm..
-stock rb30e rods
-acid bath, hone, bore, balance
-harmonic balancer?? stock 25? 30?
-King or ACL bearings, i was going for ACL but my machinist told me to get kings as their "cheaper and better"
-rb25det pumps
-head gasket undecided
my block party
the series 2 head -stripped acid bathed, crack tested
cheers
http://www.spoolimports.com/content/SPOOLR...SHORTMOTORS.asp
check this out. im looking at doing the same thing as you so good luck :D
  • 2 months later...
after getting ripped off by hitech cylinder heads and them not doing the work they were meant to do what with: buying wrong timing belt, not putting clutch on, or timing belt, tensioners, cams gears, they drilled a hole in the cylinder head (instead of the internal feed like they were meant to) they also didnt tap the hole, they didnt supply any hoses for the extenal feed or connectors, didnt relocate the tensioner above the water pump etc etc + kept increasing their price and abused me other day when i told them i want them to pay for some of the work that ovaboost have had to do that i already paid him for!
-Mick at ovaboost told me that last week Tony from hitech called him to ask how to do an rb25/30 because he has someone else's engine sitting in his shop right now.
i really hope its no one from here.
in some good news! got a call form ovaboost today saying it has excellent compression on all cylinders and after all the work they have had to do to the engine and few issues with exhaust manifolds and some custom fab work, its nearly ready to start! will post a dyno result soon ;)
Edited by Char
This is probably a bit late in the piece but ive had both a .82 and 1.06 setup on my rb30. The spool time difference is so negligable that id reccomend the 1.06 every time. The .82 was snappy and use to make the car wheelspin everywhere, whereas the 1.06 comes on more progressively.
I havent had them dynoed back to back as the car cracked the oil pump on the dyno but will in the next few months.
By the way, get a better turbo manifold, bigger wastegate and think about mounting the gate out the exhaust housing. I spent ages trying to get my boost control perfect and in the end put a 48mm Turbosmart gate out the housing. Boost control is perfect now. Should have done it earlier.
Engine specs
rb30det with 32 head
cam gears with performance springs valve springs
sinco customs manifold (similar to 6boost)
link ecu
mitsi evo 3 coils running wasted spark
8.5 compression - standard rebuild
310kws on the old housing at 18psi
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
