Hi guys,
just bought an 1999 R34 GTR a few weeks back.
The headlights look yellowish most probably because of burnt water/fog in the inside of the headlight.
I couldnt find any topics that was telling how to clean them.
I was thinking about putting the HL in the oven in order to melt the seal, then clean it and finnaly buy some black seal glue to put it back together but it might get a bit messy as i've got 2 left hands.
any other ideas?
cheers
https://www.sau.com.au/forums/topic/326373-headlights-yellowish-on-my-r34-gtr/
i dont know where u are located but there is a place in melbourne called headlights +
they do all thet sort of stuff and it seems to last very well (better than the kits u can buy)
also if u do buy a kit be careful a mate of mine coroded the film off his lights because it was a very strong sort of polish/cleaner.
Depending on the headlights, some frost over due to the Australian climate and the extreme UV we experience, (others due to a poor seal.) these lenses are designed for the Japanese climate and UV rating. A good plastic polish will bring them back, brands such as mothers are a good bet and arnt too badly priced.....
I've tried many things previously on my headlights - anything from brasso, sandpaper, and PlasticX etc - all of them worked, but some had better finishes than others. All of them started going yellow again after 6-9 months though...
I just used glassylite on my headlights on Thursday night - easy system - brought them up crystal clear and got rid of the yellowing in my passenger-side R34 lense. The final UV coating you apply is supposed to help with Australian conditions and prevent the yellowing from occuring again. For the price I paid (maybe $35 incl. p&h from their website) I figured it was worth a go - especially given they claim it's got that UV sealant/protectant. Purely on their initial results of making them nice and non-yellow and clear - I would highly recommend it - it works.
Only time will tell whether it resolves the yellowing coming back every 6+ months :whoops:
I used all of the above methods and can still see fine fracture marks and what looks like dried mosture on the INSIDE .. so nothing will fix them up from the outside. But they're not yellow at all ..just slightly faded in corners.
I used a series of fine grit sandpapers soaked in warm water, sanded the outside of the headlights, then soaked the headlights in a thick thich coat of plastic polish and they come up like brand new.
Only time will tell whether it resolves the yellowing coming back every 6+ months :D
Keep us updated on 'glassylite' because I've wondered (also being a chemist) what it is that causes the yellowing to return so soon?
In any case, if this has an effective UV sealant/protectant, I won't have to keep on rubbing my left hand headlight (on the Forester) like a genie bottle. My GT-R has no such dilemma. :D
No signs of yellowing yet - but it's still early days.
What I found interesting is I've never had yellowing issues on my drivers-side light, only the passenger side - perhaps one has been changed in Japan before I bought the car, or maybe one's had the coating scrubbed off at some point from over-zealous polishing - who knows.
I plan on keeping this thread updated, if I see yellowing return tho - never fear :D
I'll also be interested in hearing how this goes. I've been using Meguiar's PlastX - works well enough, though my driver's side headlight still has a very faint tinge to it. But at least I can actually see into them now, so bonus!
Plastx can work very well. I have used it on a number of cars with generally very good results, especially when using it with a car polisher ( gently )
Once that yellow starts though it will need redoing periodically
Hi guys,
any other ideas?
cheers
My headlights we're yellow too, I got some headlight cleaner stuff from SuperCheap Auto and it seemed to work pretty good, just follow the instructions and you'll have no probs :blink:
  • 3 weeks later...
I "think" the yellowing is cause by some sort on algae. Since the lense is quite porous and rain water isn't clean it leaves the ultimate place for algae to form.
- Polish the lense with any car polish.
- I found a little bit of RainX helps keep it clearer longer, maybe because it repels water better and "fills in" the mircoscopic pores on the lense.
But that's my own non-scientifically proven theory anyway - which seems to work :P
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
