One question to all the Mines haters.
Have you actually had one in your car and has it caused issues?
I understand the theory behind what you are saying, but as soon as you modify the exhaust/boost/cooler/intake then the standard ECU is not longer tuned for your car either.
I've not used a Mines so am not speaking from personal experience but I've seen a ton of people on here poo-pooing them with what seems to be no actual evidence to support the criticism however many people who have run them or do run them are generally always speaking out in support of chipped ECUs like a Mines.
So may I ask those who are so critical of chipped ECUs to actually support their theory with some evidence?
Again, I'm not pro or against them as I've never used one, but it seems people who have on here have had generally good experiences.
  • Replies 126
The only mods he has done is an exhaust and upped the boost. The first issue to me is the boost spiking, this to me identifies something else is wrong.
If he drops the boost I cant see why the standard ecu cant cope or even the mines for that matter. Its not like he has considerable modifications. I agree that a tune would help a lot but it doesnt appear to be the issue yet.
I was running 12psi, had an intercooler and exhaust and that was enough to get complete boost cut where the ecu kills the ignition for 2 seconds, I also got the horribly misfiring and complete lack of power over 5.5k due to it running so rich it was misfiring (below 10:1 when it got on the dyno.
The stock ecu can shit itself as soon as you start flowing much more air than standard.
I am not a Mines "hater". If you live in Japan and can take your car to Mines and get them to make a chip for your car that would be fine. But buying one off ebay and sticking it in your car is like a lottery. For some people it works better than their stock ecu but for others it may either be worse or else it may be bettr but not optimal. I have had a chipped R32 ecu running my RB25DET (245awkw) but my car was tuned on a dyno and the chip tailor made for my application. People like Toshi make mail order chips for people who list their mods and these will work better than the stock ecu and he has many happy customers, but I would never buy one because i want my tune to be spot on.
Re my post above, yes I had a mines chip in my ec, it was absolute garbage, they had to wind the cas back as it had advanced the ignition so far it would ping on 98 octane fuel with octane additive as well.
Edited by Rolls
Seen many work very well first hand. Never heard of one actually running bad, they are based on a stock car with no more than breathing mods. I personally believe limitations/expectations can be taken as the same as stock, with dyno time to support.
Have although read LOTS of non-user feedback :banana:
EXACTLY, i used two, not a problem at all. Car runs better but try telling that to non-users. Good luck. i made 210kw+ on both and no my engine didnt "BLOWWW UP"
Mine had the CAS wound all the way back to stop it pinging and ran so rich the wideband sensor was maxed out, I was even getting rich misfires so must have been around 9:1 AFRs.
So there is one example.
Thats your experience. I used PFC, stock ecu, 2x Mines ECU and about to try NISTUNE.
MINES ECU was excellent, nothing bad about my personal experience with using mines ecu. ran 13.3 with shit tires, car went nice n hard, thrashed it. never missed a beat, even in 38c degree heat when i took it to heathcote.
Running an off the shelf remap is always going to be dicey, just because it works some times does not mean it is a good idea.
Everything is dicey. Tuning, modding up the car. You waking up and getting out of bed if "dicey". IT WORKED IN MY case is what im trying to say, just as well as PFC.
Or I could just pay the $300 to get it tuned and not worry about it :ph34r:
300?
First tune was 950.
My second was 1550 including some other work..
And now my 3rd is 900-1000.
point is?-its never 300, not in my case anyway.
But anyway, we could go all day. i get what your saying, it is less riskier, if you tune your car. What some people dont get is MINES ecu can work, but dont want to even hear about it. In any case, me no care, ill butt out.
As said previously, this guys setup is hardly highly modified it really only has an exhaust and some more boost. Once he drops the boost I don't see why the stock ecu or a mines ecu can't do a reasonable job.
has this seriously been going for 4 pages...
just turn down the boost... youve basically got a standard gtst there.
want more power spend more money, its pretty straight forward I would of thought...
What mods did the car have?
If you read the title of the thread you will see that the focus of the OP is to go faster. To do that he will need a tunable ecu. If he goes to EFI they will sort out his other problems. His own understanding of how things work appears to be limited.
If you read the actual thread he has a lot more basic problems to fix before he worries about modifications for more power.
You are spot on, you cant just turn up the boost and expect power, you need to modify the car, exhaust, cooler, maybe fresh coil pack before even considering turning up the boost BUT, i can assure you that OP problem is not ECU as i used this ecu previously. Its something else, the problem was there even before Mines ecu, and my suggestion is to get good flowing exhaust, good cooler, coil pack and turbo tech manual boost T. And than run 12psi. Thats how i made 208 kw, and you should too providing rest of your car is in good nic. :D
why on earth did the PFC not work? in 12 years of playing with them not once has there been an issue like yours...... in fact the PFC ignores allot of minor issues the NISTUNE wont, chances are the nistune will be worse than the PFC in your case. The PFC only cares for AFM voltage, tps and CAS the rest it ignores..... the NIstune requires just about every sensor to be in check or it will throw a code and depending on the model may not have a DTC check box to keep it ignored.
If the PFC wont run either the tuner CBF'd or they didnt tune it..... there is an underlying issue with your car that wont be sorted with any management, which can often be a biatch to find. Any good workshop should have no issues though.
If it was me id have the PFC back in it in a heartbeat.... and find the issue.
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
