This is the pic that Khaled took of my car in the pits, had him email me the high res version for my desktop and he also sent a few variations
appreciate it mate :P
What a hardparker, posing at the drag strip. You love it :) <3
Nice photos
hey guys
ive uploaded most of the pictures i had worth uploading.
nutr33 was.. well .. nuts! almost wheels up launches and driving it that hard with radials up front was awesome to watch!
http://s55.photobucket.com/albums/g144/Ang...y%203rd%202010/
most pics are slightly bias towards my friends GTS"R" coupes.
will try to upload ones i may of missed when i uploaded a heap in a rush on sunday morning.
Edited by Angry
appreciate it mate :wub:
Thanks. It was please dealing with your Nick. :wub:
What a hardparker, posing at the drag strip. You love it :wub: <3
Nice photos
You gatta admit that his car is pure sex. I was starring at it the whole way to the drag race. BTW, Nick, I was driving in front of you with the blue STi :wub:
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
