this is the best of sau..... please post up the BEST put your average dailys in there own respective sections ie R33
Couldn't agree more. While we all think our own cars are the shit, clearly most are not even in the same league as the big hitters. If you have to post your own car in this thread, it probably doesn't belong in here.
NUR33
What are those canards called on the 33GTR and where are they purchased from?????
Hey mate they are Autoselect Carnards matched with the Autoselect Chibi Devil Front Lip got them from RHDJapan.com
i do agree with you as well as nominating your own car is like sucking your own knob - too late for me though as i already added my gtr to this thread :)
Love it how their is still this stigma attatched to R33's, my car isn't 'the best' but its the cleanest example I've seen in person, and it's won best modified car in two car shows, hence why I posted it... I'd take it but you can't edit your posts on SAU.
This thread is for the "Best of the best", not disagreeing your car isnt clean and its a nice example, but a stock looking gtst lowered a little on work wheels....really isnt the best of the best for me and probably many other people.
Also there are plenty of stunning examples of 33s in here, check out the one posted above, GTREAL and NUR33......
Well nominating yourself is one thing, sucking your own knob…that's for another thread alltogether. :P
Not sure if this has been posted yet but I'm possitive that everyone would agree that it belongs here.
there are a few ppl that would qualify that category haha
Vorse is correct...
Justin Fox's (Owner of JDMStyletuning.com)
GTR belongs here too...
More Photos & Feature here:
http://www.speedhunters.com/2011/03/car_feature_gt_gt_justin_fox_s_r32_gt_r/
Brilliant. Love it!
lol
I misread and thought it was actually a Nismo V35..... then I realised..... and was disappointed
Still a clean car but
Not quite lol, N15mo is the member's forum name.
And sinistaGTR don't hate just because we didn't get a GTS-t or GTR type spec.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
