from www.ngk.com.au
1985.8 - 1988.2 NISSAN SKYLINE 2000 - RB20E
Spark Plug Part No.
Recommended Plug BCP5ES-11
Iridium Option BCPR5EIX-11
1988.2 - 1989.11 NISSAN SKYLINE 2000 - RB20E
Spark Plug Part No.
Recommended Plug BCPR5ES-11
1985.8 - 1987.8 NISSAN SKYLINE 2000 - RB20DE
Spark Plug Part No.
Recommended Plug PFR5A-11
1987.8 - 1989.11 NISSAN SKYLINE 2000 - RB20DE
Spark Plug Part No.
Recommended Plug PFR6A-11
Iridium Option BCPR6EIX-11
1989.5 - 1993.8 NISSAN SKYLINE 2000 - RB20E
Spark Plug Part No.
1989.5 - 1991.8 (R32) NISSAN SKYLINE 2000 - RB20DE
Spark Plug Part No.
1991.8 - 1993.8 (R33) NISSAN SKYLINE 2000 - RB20DE
Spark Plug Part No.
1993.8 - 1998.5 (R33) NISSAN SKYLINE 2000 - RB20E
Spark Plug Part No.
1991.8 - 1993.8 (R33) NISSAN SKYLINE 2500 - RB25DE
Spark Plug Part No.
Recommended Plug PFR5K-11
1993.8 - 1998.5 (R33) NISSAN SKYLINE 2500 - RB25DE
Spark Plug Part No.
Recommended Plug PFR5G-11
Iridium Option BKR5EIX-11
1998.5 - 2001.6 (R34) NISSAN SKYLINE 2000 - RB20DE
Spark Plug Part No.
1998.5 - 2001.6 (R34) NISSAN SKYLINE 2500 - RB25DE
Spark Plug Part No.
search tag: R32 R33 R34 RB20 RB25 NGK spark plug part number iridium platinum
https://www.sau.com.au/forums/topic/32825-na-skyline-spark-plug-numbers/
I just changed my plugs, and i might add that the irridium option for the 89-92 R32 (b***5IE-X) or whateveris Bl***y expensive ! i got the shock of my life when i found out the price - but then i noticed the lifespan and wasn't so worried - 140,000kms - as opposed to the 35/40,000 of the copper NGKs, so given how difficult they are to change, id say it's worth it. And i also gapped them a bit closer than the previous set i had - give a *noticeable* amount of extra torque, not monstrous, but certainly more driveable, esp. on the open road. (changed from 1.1 to ~0.9 if your interested, but thats just what the plugs were factory set to) Also seems to havce improven economy a bit, but ill hold the verdict until i've played with it in some different evironments.
phil
  • 5 months later...
Just bought a set of Platinum Plugs for my R33 RB20E, cost £60.00 !!!!
The part number was PFRG5-11, these are not iridiums, does anyone know of a reason why they should not be run in this engine ??
Regards
Mark
This may seem like a totally stupid question but i just bought my R32 RB20DE two days ago, had a good look under the bonet and i am totally stumped as to where the leads and plugs are and how to change them. Ive heard the lead is a coil over, what exactly does this mean also? sorry if i sound stupid but im new to skylines so bear with me
Coil packs, they are running along the top of your head, pull off the intake, pull of the plastic cover on the head (allen keys if i remeber) and there you will see the row of 6 coilpacks and the distributer sitting at the back, which is bolted to the top of the plastic cover - Have fun when you wanna change them, set aside at least an hour.
  • 10 months later...
  • 2 years later...
hey mate...
got a r34 rb25de...
havnt had any experience changing mine but i have made a list of all the parts i may need in the future...
someone correct me if im wrong but...for our situation i think we use..
PFR5G-11
or the Iridium Option is the
BKR5EIX-11
  • 3 weeks later...
to suit r34 rb25 neo non turbo
jus want sum input on wat spark plugs r running in ur ride, copper/irridium, gaps, brand, part numbers, prices.
have dun search and came up with the following numbers, but no comments on wat examples work better then another....
PFRSG-11 guessin its copper, 11mm gap, brand unknown
BKRSEIX-11 guessin its iridium, 11mm gap, brand unknown
trying to decide between new copper plugs over short intervals or irdiums for long term and brands etc etc.
thanx
Edited by jvs007
use the ngk platinum plugs PFR6A-11 even though mine is a gt-t i have been told these plugs will work fine in the n/a skylines. you can pick them up from any supercheap auto 4 i think from memory 18 bucks each. mine had pfr8b in them then put the pfr6g in and the car is running beter than it was b4 hope this helps
those part numbers are unique to NGK plugs. a seach on the forums (and google) would have confirmed that.
Greg has already listed out the NGK numbers (with a link!!!!) on the forums: http://www.skylinesaustralia.com/forums/N-...amp;hl=platinum
ALSO
NGK (http://www.ngkspark.com.au)states:
Your Vehicle:
8/93 - 5/98 Nissan Skyline 2500 RB25DE
Spark Plug Part No.
so judging by that, the PFR5G's should be platinum
NGK have a table listing out the benefits of having different metals
reference link: http://www.ngk.com.au/pages/product_spark.htm
p.s. - all 3 threads merged! please post in existing threads in future and search a little more carefully :blink:
cheers
eug
  • 1 month later...
i have an r34 25gt and when i was going to change the coilpacks i thought id get some new spark plugs too. so i bought the ngk iridiums and i got all 6 for 70 bucks at repco. when i installed them i found out my car had the same ones in there, so they must be good, now i dont have to worry about them for ages.
  • 11 months later...
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
