  • Replies 68
Posted Images
Just grab the usual injector, pump and ECU upgrade and enjoy the power. I assume you have a manifold and know this wont go near bolting up to the std manifold. If you decide its too laggy for you then I have an 8cm housing that will bring it on qbout 300-400rpm earlier that i would be interested in swapping for your 10cm housing
my favourite RB25 turbo setup. I have done about 6 or 7 now. The latest was low mount external gate. 320rwkw on 18psi completely std internals.
You will love it, should be reliable if done correctly.
This is a customers 4door R33 (std internals apart from 260 drop in cams and no vct) 6boost manifold, blitz gate and T67....
320kw!
that is massive... i've got 280kw with 17psi
Ill be making a manifold or adaptor myself. What is the boost limt i can run and what power at which psi have you guys seen with this setup? Also where can i get springs for the trust wastegate?
i have a high mount trust manifold here i've been tryin to sell if you want, make me a reasonable offer and its yours.
Just had the car pictured above on the dyno, only change was we fitted a set of Camtech drop in's (http://www.skylinesaustralia.com/forums/Rb20-Rb26-Rb26-Camshaft-t308743.html) Car still has std head and bottom end.
Blue is before cams.
Red is after cams.
Nope, thats why ill get it going on say 7psi now, then buy pump , injectors etc. Any more advice or info to help me along?
dude
seriously u should listen to what ppl are saying, dont just go strap on a large turbo with no supporting mods
a
just do the basic stuff
ecu or piggyback
injectors
nice dump pipe and exhaust mods
and a turbo manifold
fuel pump
then the other stuff later, u will f**k something up by doing it the way u intend on doing it, + the lag that will happen and then only 7psi comes thru might as well leave it stock till u can afford to do it properly
dude
It seems you have missed the OP's topic all together.
He is asking what else is needed once he has this turbo bolted on, and what he can do with it in the meantime. I dont see an issue, chill.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
