stop being a fkn girl n bash it out. if you replace the whole thing with a straight bit of pipe, that is stupid. I've been through an EPA test station with mine bashed out, guy asked me if it was, I replied that I hadn't touched it since I bought the car. Who was to say it hadn't blown itself out of the exhaust?
  • Replies 70
yeah, but you cant get a fine for not running a cat unless they physically remove the decat and look inside
the worst they can do is tell you to go in for a full emissions test
and "tap tap" will never hold up in court
The roadside inspection stations can and do issue fines on the spot.
You do not have to be reported for a full EPA as they have all the equipment with them on the mobile station that they setup :)
So you get a fine on-spot, and then a FULL EPA as well to go and then ensure you "comply" after the fact by "X" date.
Unless you have over 300kw most highflow cats wont make much differents to power maybe 1 - 2 kw if there half decent?
So just go highflow or if you want to run decat pipe/ gutted cat. But other than flames and nose its not going to make THAT much of a diff.
Hamish is right. I removed cat and got 5rwkw top end and 30!!!! read 30! rwkw in the midrange. makes a huge diff @ higher power figures
Also about police checking if you have a cat. What they do is measure your exhaust to see how far the cat is, then they ram a flexible rod down your exhaust. If it goes further than the measured point they know its not there. Be careful of that one!
The only way they could possibly do you for hollowing out your cat is is they pull it off. No manner of equipment, short of a long pinhole camera, is going to hold up otherwise. "Tap tap" or emissions won't prove that your cat has been bashed out. It' might prove that your cat is worn out (or hollow) and that would see you recieve a notice to fix it and maybe a small fine for having an unroadworthy car.
"It was like that when I got it" would easily see you walk away from court with an order to fix it and a reprimand for the police for wasting the courts time with such trivial matters when a simple "fix it, take it the VicRoads for an inspection when you do and don't do it again" would have sufficed in the first place unless it's the 8th time you've been done for these types of offenses.
do cops here in nsw go these extreme measures ?
what if u bought a car with a bashed out cat and u did not know about it? and happen to get done for it? guess its still your fault as your in posestion of the car...suxks i guess
just go high flow and u have nothing to worry about
yeh, i get that, but what i meant was you cant get a fine for not having a cat unless they pull it...
you can and will get a fine for noise etc
Mine has a relatively new high flow cat and still blows massive flames now and then, it has a fairly rich tune as it was just to get me through an inspection so quite a bit of fuel on the overrun, has anyone experienced this? Would be surprised if someone had piped it, certainly doesn't look like it.
i got a high flow and it apparently pops flames
and youd be pretty unlucky to actually get done by a cop for a gutted cat
Kinda skipped ahead on the thread here to add an after thought;
Hi-flow cats aren't expensive. The people upgrading them have usually spent many thousands upgrading fuel and air systems already, and with the quality of metal cats and the likes nowadays, why wouldn't you use one?
I've read time and time again you will hardly get ANY performance gains between a decat and hi-flow, so why would you knowingly poison our atmosphere, and (not aiming at anyone in particular) add to the negativity that these cars already receive?
Not to mention the damage to your car, the 'book being thrown at you', etc
Is 10kw (or less) really that important?
Always use a cat. Read around, the days of negativity regarding cats are diminishing.
Edit (I was also under the optimistic impression that people who own 350+kw cars understand how they work - including the cat - and can weigh the goods and bads (as they would with their self control of their right foot) and hopefully choose the right thing to do here.
http://en.wikipedia.org/wiki/Catalytic_converter
Edited by GTRPowa
Read the thread mate. I mentioned the power difference between a high flow cat and a de cat on my car. Huge difference in mid range power/torque
Your results don't make much sense, it should cause the biggest increase in power towards redline, not in the midrange. Was it a back to back dyno on the same day?
Edited by Rolls
Which cat did you have? "high flow" can mean different things to different people - especially if you work in the marketing department for a cat converter company....
For me, not running a cat is for people that piss in the street and throw McDs wrappers out the window... low brow.
I can certainly tell if there is a CAT or no CAT with my 3.5" exhaust :D
CAT is a CATCO 4" item, and without a doubt I can tell performance wise.
Doesn't show particularly much on the dyno however as it is more in throttle response and similar which is not really evident on rollers.
Hence i always say get the biggest CAT you can, 4" (if you are a 3" exhaust) or 4.5" is you are 3.5"
what about people that run a decat AND e85?
As we are still running 15 percent petrol they will always force e85 cars to run one, until they exempt ethanol from their silly emissions ideas like they did with LPG (and allow straight ethanol) we are going to have to leave the exhaust blocker there. :/
I would be interested to see these gains for myself...
I am in the process of making a quieter (stealth) system, I bought a 4 inch highflow but I would like to fit a decat while on the rollers to see what all the fuss is about. Is it worth trying?
I had better order some more flanges. :/
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
