I had a good look underneath the car today just to check for any problems and came across evidence of a small leak.
I'm unsure if this is a common thing on the M35's but just looking if anyone can help give me an idea where this leak is coming from.
From what I can see, it looks like it might be coming from loose hose clip.
The leak doesn't seem major, and there's no drips under the car overnight so far.
Looking at sorting out the leak, if anyone has any idea or can help, your input would be appreciated :)
https://www.sau.com.au/forums/topic/328637-help-with-leak-under-nm35/
Small leak? :down:
It could be a few things, most likely the rear of the passenger side rocker cover, they are well known to leak from there. Fixed with a replacement rocker gasket.
It could also be one of the plug hole seals, mine had completely filled the rear plug and spilt out under acceleration. Fixed with a smear of silicone.
Hopefully it isn't the oil inlet for the turbo, its a pain to get at. Can you see oil weeping from the top? See if you can get the camera in there.
Thanks Scott.
I've inspected the rest of the engine bay as much as i can but couldn't trace it any further than that clip and where the arrows are.
I can't see anywhere else where the leak is coming from besides this part.
It doesn't seem to be leaking much (as in there are no visible drops on the ground yet). The car should still be fine to drive for now, right?
Hey Dimi, you picked it up last week so it's still under warranty. Take it back and ask them nicely if they can rectify the problem? You didn't pay for a car with an oil leak so they should have no problem fixing it for you.
Hey fellas, appreciate all your help! :)
I think it is engine oil.
You might be right though. They might have fixed the leak already because it doesn't seem to be dripping at all.
So what i'll do is degrease it and sus it out after a good 100kms worth of driving. If the leak persists, i'll contact the dealer and ask them if they could rectify it. They should be cool about fixing up the leak, right?
I might give them a call today at lunch and ask them if they sorted out or noticed a leak before.
Edited by dimi108
Okay, so i degreased everything and took it for a good 100km drive.
I can now see more clearly where the leak is coming from.
The leak is there and i can smell it when the car is at idle with the fan on.
It's at this odd location just on top of the turbo.
What are your recommendations on this? Take it back to the dealer and ask them to help me rectify the leak? I've only had the car for 7 days.
Edited by dimi108
My car is leaking slowly from the same spot, it is the rubber rocker gasket by the looks of it. They will probably order one in and fix it, you could of course get it yourself and fit it if the dealer isn't local.
I would change the plugs while you're there if they haven't been done already.
Yours is doing the same thing?
I see. Well at least i now know it's not an "impossible fix".
It seems like a slow leak on mine too.
How long has yours been leaking for Scott?
Edited by dimi108
this
pretty sure they have to fix it under the statutory warranty that you get from a dealer - 1 month and 5000(?) kms i think
How it passed a roadworthy with that much oil underneath, I have no idea.
I fixed mine myself as I didn't want the dealer touching anything else on the car... I should have bought a new seal though, instead I used silicone and it only lasted a few months.
Thanks fellas. I called them and they were nice about it. I'm going to go there this afternoon to have a chat then i'll leave the car with them on Sunday afternoon. Hopefully it doesn't take long to repair.
    • Hi guys, long time no post as per usual! It's been a busy year so far, the biggest thing being a new job.  After 28 years in the automotive industry I decided it was time for a change.  I was losing faith in the industry and where it's heading.  Now in a completely different industry (electrical) working for a company that manufacture water pump contollers.  Not as sexy as cars but it's an interesting,  challenging industry. I now don't work Saturdays which is a bonus!  It's still 50-55 hours a week but having Saturdays ack after 28 years of working them is awesome!   No news on the GT-R but i did decide to add some more JDM goodness into my life....           1990 300 ZX.  She's not perfect but for a 35 year old car she ain't bad!  Just going to tidy it up a bit and enjoy it.  It's currently auto but will start stockpiling everything for a manual swap. It WILL distract me even further from the GT-R but im hoping not for too long! It somewhat proves a 6'8" freak can fit in a 300 ZX.  Sort of...  I drove it home from the previous owners house in Melbourne via Black Spur and Merton Gap (2 awesome bits of Victorian twisty road) and it was amazing!  Handles so well!!!   I don't think it would be worthy of a full build page but I'll post up some of the upgrades here if anyone is interested?  Cheers guys!
    • End game is to: - Remove all the slop from old worn parts - Adjust setup so that the wheels actually fit and the car is drivable (currently it is not because of the extreme rubbing on the guards).   Progress over the last couple of days, removed the rear hubs! Next steps: - Buy bushings - Replace bushings/bearings on hub - Reinstall
    • Cracked deck  And other cam snap stuff
    • A few random issues have popped up since my last update. My WMI pressure sensor failed within about 10 minutes of it seeing liquid. It was a 20$ China special, so I'm not surprised. My name brand replacement should arrive today.  My power steering assist also decided to crap out last weekend. The usual, works for about 60 seconds after starting the car then I lose it. I dusted off my old copy of NDS and connected to the HICAS ECU. Code 4 for assist solenoid.... I tested the solenoid and it's fine.  I knew the day where my HICAS ecu would crap out would come, and I welcome it. It was the last HICAS part on the car that is now in the bin. I've ordered an SSR and I will control the power steering solenoid with my Haltech ecu. It will be nice to have proper speed referenced assist again after all these years.
