Proudly Presents:
Micolour SAU-Vic DECA Motorkhana ROUND 3of4 of the 2010 DECA CHAMPIONSHIP
When : Saturday 14th August 2010
Where : DECA - Shepparton, 145 Wanganui Road, Shepparton, VIC 3630
Cost : $85
Max Entries : 50 + Reserves
-= PLEASE NOTE =-
The insurer of the event (AASA) has issued supplimentary regulations that require all entrants to wear helmets during all competition. This includes the skidpan and all battles.
This also impacts passengers, as they must also now wear a helmet prior to entering a competition vehicle.
A fire extinguisher is required by all entrants. This is for your own safety.
Please re-read the supplimentary regulations before entering the event.
Entry Form & Supp. Regs. : ENTRY FORM
Event Schedule: Event Sched
Results: Not yet available
YOU WILL NOT BE PUT ON THE LIST WITHOUT SENDING AN ENTRY FORM. NO EXCEPTIONS
All withdrawles will be refunded after the event. Refunds will not be given after 5pm Monday 9th August.
Anyone paying by cheque MUST make the cheque out to Skylines Australia Victoria. Cheques made out to anything else WILL BE REJECTED.
Please support our sponsors : Micolour - Custom Refinishing, 7 Dissik St Cheltenham 3192, Ph: (03) 9555 8011.
1 Ryan Bell Micolour Sileighty***
2 Michael Eichorn Micolour Sileighty***
3 Tim Williamson Micolour R32GTST
4 Martin Sullivan S14
5 Leon Stapley MK1 Cortina
6 Stephen Hugh-Smith Supra
7 Terence Ho R33GTST
8 Gerald Tan Supra
9 Shane Janssen R33GTR
10 Greg Calmer S13
11 Roman Plotnikov 180sx
12 Dane Stokes Sti
13 Kieran Robinson Supra
14 James Dylan Fischer-Myall Sileighty
15 Jamie Lovett SS Ute
16 Sam Zimber Evo 6.5
17 John Packham S14
18 Daniel Robson Supra
19 Mohammed Tebeileh 180sx
20 Adam Birdseye R33GTST
21 Luke Schulze R33GTST
22 Allan Williams Exige
23 Jesse Carnie R31
24 Jeremy Taylor* S14
25 Dean Taylor* S14
26 Nicholas Vargheese Soarer
27 Dean Course R33GTST
28 Troy Brisby Some RB20 thing
29 John Richardson R33GTST
30 Hamish Hampton R33GTST
31 Tom Giordano R32GTST
32 Tim Bryan**** 180sx
33 Campbell Shobbrook**** 180sx
34 James Sherman Commodore
35 Marcus Stacey** E30
36 Julian Stacey** E30
37 Mario West Fiat Punto
38 Russell Cunningham R32GTST
39 Niroj Douglas R33GTST
40 David Talbot Commodore Ute
41 Matt Femino R32GTR
42 Clive Small EVO6
43 Adam Newton*** EVO4
44 Justine Shuller*** EVO4
45 Michael Gerlach Stagea
46 Grant May R33GTR
47 Ross Brown EVO6.5
48 Sandeep Abeywickrema 300zx
49 Zaver Mavany R34GTT
50 Brad Humphrys R32GTST
51 Dan Fewster S13
52 Andrew Richmond R32GTST
53 Chris Thomson R33GTR
Reserves
1 Quinton Richardson R33GTST
2
3
  • Replies 234
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
