Proudly Presents:
Micolour SAU-Vic DECA Motorkhana ROUND 3of4 of the 2010 DECA CHAMPIONSHIP
When : Saturday 14th August 2010
Where : DECA - Shepparton, 145 Wanganui Road, Shepparton, VIC 3630
Cost : $85
Max Entries : 50 + Reserves
-= PLEASE NOTE =-
The insurer of the event (AASA) has issued supplimentary regulations that require all entrants to wear helmets during all competition. This includes the skidpan and all battles.
This also impacts passengers, as they must also now wear a helmet prior to entering a competition vehicle.
A fire extinguisher is required by all entrants. This is for your own safety.
Please re-read the supplimentary regulations before entering the event.
Entry Form & Supp. Regs. : ENTRY FORM
Event Schedule: Event Sched
Results: Not yet available
YOU WILL NOT BE PUT ON THE LIST WITHOUT SENDING AN ENTRY FORM. NO EXCEPTIONS
All withdrawles will be refunded after the event. Refunds will not be given after 5pm Monday 9th August.
Anyone paying by cheque MUST make the cheque out to Skylines Australia Victoria. Cheques made out to anything else WILL BE REJECTED.
Please support our sponsors : Micolour - Custom Refinishing, 7 Dissik St Cheltenham 3192, Ph: (03) 9555 8011.
1 Ryan Bell Micolour Sileighty***
2 Michael Eichorn Micolour Sileighty***
3 Tim Williamson Micolour R32GTST
4 Martin Sullivan S14
5 Leon Stapley MK1 Cortina
6 Stephen Hugh-Smith Supra
7 Terence Ho R33GTST
8 Gerald Tan Supra
9 Shane Janssen R33GTR
10 Greg Calmer S13
11 Roman Plotnikov 180sx
12 Dane Stokes Sti
13 Kieran Robinson Supra
14 James Dylan Fischer-Myall Sileighty
15 Jamie Lovett SS Ute
16 Sam Zimber Evo 6.5
17 John Packham S14
18 Daniel Robson Supra
19 Mohammed Tebeileh 180sx
20 Adam Birdseye R33GTST
21 Luke Schulze R33GTST
22 Allan Williams Exige
23 Jesse Carnie R31
24 Jeremy Taylor* S14
25 Dean Taylor* S14
26 Nicholas Vargheese Soarer
27 Dean Course R33GTST
28 Troy Brisby Some RB20 thing
29 John Richardson R33GTST
30 Hamish Hampton R33GTST
31 Tom Giordano R32GTST
32 Tim Bryan**** 180sx
33 Campbell Shobbrook**** 180sx
34 James Sherman Commodore
35 Marcus Stacey** E30
36 Julian Stacey** E30
37 Mario West Fiat Punto
38 Russell Cunningham R32GTST
39 Niroj Douglas R33GTST
40 David Talbot Commodore Ute
41 Matt Femino R32GTR
42 Clive Small EVO6
43 Adam Newton*** EVO4
44 Justine Shuller*** EVO4
45 Michael Gerlach Stagea
46 Grant May R33GTR
47 Ross Brown EVO6.5
48 Sandeep Abeywickrema 300zx
49 Zaver Mavany R34GTT
50 Brad Humphrys R32GTST
51 Dan Fewster S13
52 Andrew Richmond R32GTST
53 Chris Thomson R33GTR
Reserves
1 Quinton Richardson R33GTST
2
3
  • Replies 234
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
