Yeah im pretty stoked with it.
Mod wise it has the usual rebuilt engine using an r33 block with forged pistons, rb30 crank girdle, ported head, cams/gears, n1 oil/water pump, -7 turbos with full exhaust and powerfc. For some reason unknown the builder decided not to put in oil restrictors or sump baffles as far as i can tell from the receipts which is a bummer. Hasn't been tuned with cams yet and only running 0.7 bar atm, hopefully get it tuned in a week or so (winton this weekend is stealing most of my left over cash) and hope for responsive near 300kw reading.
Edited by joeyta22
its actually a real nice colour, your avatar doesnt do it justice, thought it was just a gloss orange! Looks great
Cheers mate! Yea in my avatar you can't see any of the pearl because the sun was at the back of that pic.
And I would love some te37s haha. But in 19 inch they will make my wallet hurt me
lol i think you'de have to sell your left nut hahaha
This ^ so much better stuff to do with that money. TEs in 19s = :domokun: especially GTR size
i thought theyd offer a nice stance, for daily use ofcourse
    • They are, a good friend of mine bought one to replace his blow factory turbo, running a Toshi Tune reflash. Just use their supplied water/oil lines and you're good to go. At the time, they were like $900 delivered.
    • This is an option for 100% bolt on, the GCG high flow -  https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html Also, I'm pretty sure hypergear does a high flow that is 100% bolt on, it just doesn't make as much power as their bigger high flows.  Even if you get a hypergear turbo that requires you to chance the intake piping, it is a really simple modification. It can be as simple as a piece of silicon hose and you pop a filter on the end. It doesn't have to be some crazy pie cut titanium work of art intake pipe.  If you have the ability to swap the turbo yourself, you would be able to sort the intake piping out.
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
