^ looks awesome man! Still rubbing?
^^ yea i jacked it up about 3 cms and it just rubs on one tyre.
we didnt roll the guard all the way along and thats the part thats cutting in! :(
let me know when you have some free time so we can fix it.
if you want briing it down on friday or saturday?
