Hi all names josef, used to own a ADM ae86 sprinter... miss that car... here is my 3rd car i have owned (2nd was a holden vectra for daily, and 4th is a gt86 coming from nihon! happy days!)
so onto car things, boring day at work my company is new in melb so not much business, pulled my car into the factory, quick wash n some slight additions to the car and office!
so heres the specs when i bought the thing, was already done i just made it roadworthy... yeah...
mods listing
engine: rb20det (out of r32)
rb20 box manual conversion
rs yamamoto chiped ecu soon to be swapped n tuned
locked 4.33 diff
hight flowed r33 turbo
52mm radiator
twin el thurmo fans
fmic
3" turbo back exhuast with twin pipe magnaflow muffler and high flow cat
bosch 040 fuel pump
catch can
gfb boost tap
new water pump timing belt power steering pump and all belts.
new welsh plugs and rear main
pbr heavy duty clutch.
new clutch master and slave
suspention and brakes:
5 stud conversion
r32 calipers all round
new pads and roters all round
new brake master cylinder
new bc coilovers
new jic front caster arms
new jic rear camber arms
new gk tech rear toe arms
new tie rod ends
front and rear top strut braces
new soft brake lines
interior:
blue dildo shifter
r33 4 door front seats
dash mat
apexi turbo timer
sparco boost guage
tacho does not work soon to be fixed maybe if i can be bothered
sound:
very good pineer head unit
new pioneer front splits
j-car rear splits
jbl 12" sub
j-car monoblock amp
exterior:
HID low beams (replaced to better lights, standardish, these werent to good)
white led packers
window visors
roof wing
latle model chrome grill(might remove it so i dont smash it at track days or somthing... thoughts?)
17" work rims 8" front 9" rear. (paint on wheels pealing, need referb) currently running some stockers
clear front indicators
autech side skirts not on the car, anyone wanna buy em? :/
rolled rear guards
and havnt done anything else to it but got it roadworthy so ill just post some pics i took at work today n some before the clean up.
here are some pics of it chillin at home and the other set of rims i have for it.
Edited by sprinter666
Hey Josef!
Welldone with the Cefiro!
You need Panasport G7's :D
Like Chris' car.
lol no moneys! still need to fix the thing! besides i rkn kriss's is alot neater have u sean my dozy bonnet n all the dints hahaha, kriss lend me your rimes ;) ill leand you mine :P deal!
Gave her the first wash today to look for imperfections, minor stone chips was all I found!
But definitely needs a good detail. Need some more money's for immaculate reflections to do it lol
Big spec Josef... Forgive me but what are soft brake lines? New flexible brake lines perhaps or a brand?
man no idea was on the receipt/build list i just copied it id just assume their new regular brake lines uness their those reinforced soft lines with wire i them? kinda like fuel lines since last time i did fuel lines on a car they have some kinda braided wire in them for reinforcement etc? just my guess.
ask ross? lol brakes work perfect all i care about :P
p.s.: go shockworks xD people in SAU even know em now epic work! chris n brett are guns! xD
    • Next, remove the upper and lower radiator hoses, both are held with a spring clamp. While you are under there, tackle the Auto Trans cooler lines.  Again both are held on with spring clamps, and as mentioned above you should cap them on the radiator side with an 8mm cap, and on the car side loop them with a length of 8mm pipe - this will stop you losing a dangerous amount of AT fluid during the rest of the job If you've been meaning to add a sender for AT trans temp, this is a great time to do it; put a sender fitting into the passenger side line as that is the inlet to the cooler/radiator.
    • Next you need to remove the intake duct (as with pretty much every job on these cars), it is a series of clips you gently remove with a flat bladed screwdriver. They do get brittle with time and can break, and I have not found a decent quality aftermarket one that fits (they are all too soft or flimsy and don't last either) but the nissan ones are a couple of bucks each (ouch).  Once the clips are off (either 8 or 10, I didn't check) you lift the intake duct out and will see the reservoirs Undo the line into the radiator side cap (some bent needle nosed piers are awesome for spring clamps) and then remove the 4x 10m nuts that hold both in place.  I didn't get these pics, but remove the line under the radiator reservoir (spring clamp again) then remove that reservoir. Then you can get at the intake reservoir, same thing, spring clamp underneath then remove it. BTW This is a great time to put in a larger (+70%) combined reservoir that AMS makes..... https://www.amsperformance.com/product/q50-q60-red-alpha-coolant-expansion-tank/ They also make an Infiniti branded and part# version if that is your thing
    • To drain the Intake Heat Exchanger, there is a crappy drain plug in front of the driver's side front tyre: You should use the largest headed phillips screwdriver you had, and in my case I needed vice grips on the hose above as the plug was tight (tighter than it needed to be, since it has an o-ring seal).  After you have a tray down and open the drain, open the intake heat exchanger reservoir cap (drivers side one) and you should get a couple of litres of coolant To get to the radiator, you need to remove the plastic engine undertray. It is held on with a series of 10mm headed bolts and some clips. For the radiator, there is another type of crappy drain (kind of like a plastic banjo bolt) and you should attach a length of hose to direct the stream of coolant per this pic (otherwise the coolant hits the rad support and goes everywhere). The drain is on the rear of the radiator on the driver's side and a bit hard to find. Put a big tray or bucket down (5l won't be enough) and slowly unscrew the fitting by hand. You only want to remove it far enough for coolant to flow, it you unscrew it right out the whole fitting and direction pipe will come off and you will get a coolant bath (yum!). Undo the radiator reservoir cap and it should empty about 8l
    • So, this shouldn't be such a mission, but there were a few tricks so I thought I'd post up a DIY for it. This was on a Q50 Red Sport but I doubt any other V37 model is very different (maybe just less steps for the intake heat exchanger hoses) I pulled the radiator out to flush it because the car was running hot at the track, but obviously the same steps apply for changing a radiator for any reason including an upgrade. If you are removing the radiator, you of course need to drain and refill, so have 5+ litres of blue coolant ready. You also need to drain the intake heat exchanger to remove the radiator so you will need a couple of litres for that as well. You will also need something to deal with the auto transmission lines, I used 2x 8mm rubber caps on the radiator side, and a short length of 8mm pipe on the car side.....unless you can block these lines quickly you will loose AT fluid and it may be enough to hurt the transmission if you don't refill it. 2 other tools that really help dealing with coolant lines and spring clamps are Bent Needle Nose pliers Hose pliers Between them they will reduce the frustration (and injury) potential by about 1000% Other than that....lets go... "First, jack up your car". Yes really, and put it safely on stands. If you are not confident doing that you need to give this job to a mechanic
    • If the forester is anything like our old 2007 GTB Liberty, I could near on run ling Long's and "rate them", as no matter what, it just hung to the road, even when abusing it in a hard launch in the wet, or throwing it at corners.
