Well DECA is upon us again.
As always, the event wont go ahead unless we get people to help out on the day.
So we are calling for your assistance - if your willing to help, or if your bringing a friend/partner who's willing to help - please speak up.
We can explain what you need to do if you haven't done it before, so don't stress about that.
It is VERY easy stuff! and you will get a great view of the action!!
(very good for you budding photographers)
All officials will be given a free lunch and water during the day.
We also need all officials to be at DECA by 8.00am on Saturday morning - same time as competitors.
Chair, sunscreen, hat etc all make this into a relaxing day
A Slight change to previous events. we will be organizing Volunteers prior to the Drivers Briefing.
And until all slots are filled Drivers briefing will NOT go ahead and the event will not start.
I know it sounds harsh but without these people we cannot run the event.
Please PM me if you are able to help out. even if just for 1/2 a day.
cheers
Martin
Morning
Long Wang
Starter - Bec
Finisher/Timer (flying finish, can be 1 person) - rob
Flag point 1 -karen
Flag point 2 – Anna
Mini Wang
Starter - Dan
Finisher/Timer (2) - michelle
Skidpan
Timer - Wynn
Hat Removalist/starter - Al
Afternoon
Skidpan
Starter
Timer 1 - Wynn
Timer 2 -
Time Recorder -
Hat Removalist -
Hat Removalist -
See you all there!!!!
https://www.sau.com.au/forums/topic/330245-deca-volunteers/
Hi Martin,
Count me in again. Only catch is I am only available half a day this time, have to scoot around 12-12:30 at latest for my nephews birthday. Happy to do long wang in morning if you guys want, but if theres no one who can cover me for the last 1/2 hour to an hour that it's running I might be better off on the skidpan in the morning - at least then I can get one of the people who arent driving at the time to fill in for me. (From past events long wang normally finishes about 1 I think??) Happy either way - I will leave it up to you guys. :ninja:
Cheers,
Anna
https://www.sau.com.au/forums/topic/330245-deca-volunteers/#findComment-5364666
Willing to help. can be there all day. Don't have a preferred event to do, so take your pick :blink:
What time do i have to be there by? was actually thinking of driving there in the morning & driving back at night. Sorry, this is my first time, so I don't know if it's best to stay overnight or can drive for the day? :P
https://www.sau.com.au/forums/topic/330245-deca-volunteers/#findComment-5365146
Willing to help. can be there all day. Don't have a preferred event to do, so take your pick :P
What time do i have to be there by? was actually thinking of driving there in the morning & driving back at night. Sorry, this is my first time, so I don't know if it's best to stay overnight or can drive for the day? :)
Wynn - as stated in Martins first post, we need all officials at DECA by 8am on the Saturday morning.
A day trip is defiantely doable, its completely your call. There is a lot of us staying up there for the entire weekend. Check out the accommodation thread if you are keen to stay.
Cheers,
Bec
PS. Will run long wang :P
https://www.sau.com.au/forums/topic/330245-deca-volunteers/#findComment-5366185
Hi Martin,
Count me in again. Only catch is I am only available half a day this time, have to scoot around 12-12:30 at latest for my nephews birthday. Happy to do long wang in morning if you guys want, but if theres no one who can cover me for the last 1/2 hour to an hour that it's running I might be better off on the skidpan in the morning - at least then I can get one of the people who arent driving at the time to fill in for me. (From past events long wang normally finishes about 1 I think??) Happy either way - I will leave it up to you guys. ;)
Cheers,
Anna
Disregard this - I changed my mind and told them that I will get there when I get there :D
Count me in for long wang as a flaggy all morning please :(
https://www.sau.com.au/forums/topic/330245-deca-volunteers/#findComment-5369185
Can't make it this time but it's awesome for whoever hasn't done it before. Easy stuff and get to see people run into cones n stuff. Oh and then trying to find them when they are dragged halfway across the track lol
https://www.sau.com.au/forums/topic/330245-deca-volunteers/#findComment-5384325
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
