For those who don't have access to Snap-On gear, use an El-cheapo flare nut spanner with vise grips around the spanner to stop it expanding and thus slipping over the castellations.
A fault often overlooked with old brake hoses is that they shrink internally with age.
So they're OK when applying the brakes but ever so slow to return the fluid to the master cylinder, causing dragging brakes.
Whether or not you're using the flare nut spanners, it's always good to crack the fitting by lightly hitting the spanner with a hammer to loosen the nut. The impact force is usually enough to crack the fitting well before you start rounding the nut, as opposed to a constant load which won't free the threads. This has worked for me even on 35 year old datsuns and rotary mazdas, and even old british cars, so it does work.
As for pedal feel, you will get slightly less pedal movement under heavy braking, but don't expect major difference in feel. If the pedal feels very different after fitting braided lines, then there is probably something wrong. specially if the pedal actually feels softer after you've finished.
... and even old british cars, so it does work...
No dice... even the tires on old british cars leak oil, so EVERY nut on something like and old triumph can be considered self lubricating.
Another note of safety... PAY ATTENTION TO WHAT YOUR DOING WHEN SCREWING THE LINE INTO THE BACK OF THE CALIPER!!!!
i was educating the little brother in law about car maintenance while screwing it in... the lines are hard.. the calipers are soft... it went in at an angle and as some of you might have noticed if you troll the wtb thread... i'm not purchasing a new set of rear calipers.
Just because i really enjoy sharing how retarded i can be at times.
This is what happens when you dont pay attention to what your doing. Soft alloy calipers + nice hard brake lines + me == fail!
Talented arent i.
Replaced now though and alls well.
  • 1 month later...
^ You are talented!
We all have special talents. Mine being breaking a "breaker bar" (lol) but trying to undo the welded side of an engine mount nut :domokun:
I lol'd.
Edit: oops, reason i replied,
Thanks for the writeup! I have my set sitting here waiting to go in with some new pads :) Might as well write back with my findings too.
Edited by gotRICE?
Yes very easy to round them :P
I looked into the sealant thing prior to doing them as I was a bit curious whether to use some or not.
From my understanding you should only use the sealant going into the caliper (not on the other side going into the hard line) however it MUST be a liquid/gel type sealant and not thread tape. Since you are bleeding the brakes afterwards, any slight residue should come through during bleeding if you did happen to put to much on.
In theory the threads don't 'see' pressure since the sealing is done by the two thingies which mate together (not sure what they called) - Know what I mean?
nice diy!
got my car in the shop at the moment and have some of these going on also - pretty much doing brake pads / lines / rotors / shims etc - so looking forward to see how it all turns out
So installed mine. Piece of piss. Did it all from memory of this thread.
Not quite sure if its just that you Aussies are Animals or what :P , but the nuts holding the lines into the caliper and into the hardline against the body were a sinch to undo lol. I didnt even touch the car with any penetrator. Stuck a regular spanner on it and tapped it with a rubber mallet. Undid like a normal bolt :)
Only think i noticed that i was to start with, a little weary about was that as you can see in this picture:
http://www.skylinesa...ttach_id=297489
Where the line exits the caliper, the arc it makes to head off to the bracket is quite close to the swaybar, and at full lock it does come into contact with it. But i figured, so long as you inspect them every time you have the car on the hoist or when you get your cars inspected for roadworthyness or whatever you dudes call it over there, it should be fine. Im just more cautious about having full lock. I get guard rub anyway so am already gentle with lock.
Very happy with them though :)
EDIT: Lol i just noticed you have the exact same shocks as me too. I could claim that as my car and noone would be the wiser :D haha.
Edited by gotRICE?
I think you mean the castor rod, not the swaybar. (the swaybar is the silver one in the picture).
On full lock mine doesn't touch, I checked that when installing. I know in that picture from that angle it kind of looks close but there is actually a bit of room.
If yours does touch that leads me to think that perhaps it is due to your car being slightly lower than my car? Perhaps if it was slightly raised it wouldn't?
Not sure but I suppose it does make sense given that the suspension geometry tucks inwards (negative camber) and would bring the caliper closer to the castor rod.
Yes sorry your correct :)
lower could be why. I havnt been under the car since it was done, but now i think about it, with the suspension drooping like it was and going lock to lock isnt going to be the same as when the cars sitting on its wheels. Ill have a poke around next time its on a hoist.
One thing i have noticed that i like is the feel of them. Braking as normal feels the same, but progressively leaning on them harder theres a huge difference. A much nicer solid feel when you apply some weight to them. Very happy!
As far as I am aware it was a factory option so any year can have it. Just pop the bonnet and have a look if you have a big ABS unit in the top right hand corner with heaps of hard lines going in and out of it.
  • 3 weeks later...
  • 1 month later...
  • 2 months later...
just having a problem with install on the front, where the hose meets existing hard line, once tightened, there is still play up and down the line, as in the hard line flare isnt flush against the nut
anyone else run into this?
Hmm, Is that a GTR?
Cos im pretty sure that on both the front and the rear of mine (R33 GTSt) the line went into the caliper itself.
That, and the front hose on mine was FAR longer than that. But the rears were that short.
Could be incorrect flare style. If you can still move the hard line when it's tight then the to flare faces aren't mating. Check that the correct flare has been used to make the hose against the hard line flare. Otherwise it could be that your hard pipe flare is fingered.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
    • What ECU are you running? This is probably the biggest question. If it's a PowerFC, I'd probably change the ECU and get something newer that will handle the injectors in a nicer way.
