Sounds like a sorted package. I personally wouldnt bother with cams. I think std are fine. That said I do have some Tomei 256/8.5mm cams that may get a god in a few weeks when my car finally goes E85. Perhaps they will work, but I suspect I will lose power again.I will be sure to report back either way.
And just got back from the SAU Nationals where the car ran pretty well all day. A few little gremlins that hurt early running but car drive home which is the main thing. I think its time for a compression test to see how the engine is holding up.
Cheers roy and yeh i think it shall be killa,just gotta wait for the install and tune now to see how she goes..
goodluck with the car and i will be interested to see how the cams go.
So car is booked in for rail install the week after next. About time I get the rails from underneath teh desk at work and in the car. Keen to get the interior finally sorted in my car....though a little sad that this will mean the demise of the ability to install road seats :(
New weld in chrome moly mounts
New OMP side mounts
And new Sparco seat
What pads are you running? I had shuddering problems with my stoptech rotors, and endless pads. I skimmed the rotors, and changed to Hawks and it made a big difference, but they still have a shudder. Just wondering if it's the rotors?
Not the rotors. Its all tied back to the Performance Friction PFC06 pads I was running. They didnt like street driving and resutled in uneven pad deposits on the rotors. Then the problem was I didnt get the rotors ground when installed RB74s so had problems bedding the new pads because the old PFC06 material was still on the rotor. This mean the RB74s kept glazing. So after every session I removed the pads and gave them a rub on the concrete and all was good for a few laps until they glazed over again.
Each session they got better, I am expecting at PI this weekend I may have to do it one more time but I think I have just about all the old pad material removed y just general use
Private seller locally. Yeah had a look overseas for what they're worth, i think here they're something like $2400 or so
I had it for sale for a while for cheap and it's in basically new condition, there's only 1 small 10c size mark on it. But decided to keep it cause I'll eventually be able to use it
Just got back from Phillip Island and the good news is a did a 1:48/1:49. Need to look closer at the footage to see what the actual time is.
The bad news is I backed to back the footage of the car on the track before I put on the 6boost and Plazmaman inlet and the old setup hammered the current in a straight line. So compression test the engine and pulling off the Plazmaman. I was in two minds but you see how much quicker then car was with the std inlet and there is no contest. Its that obvious :(
I want to go back next weekend as there is another PI day. I have a gearbox leak that stopped me going out and giving it a good go with the right pressures. Car was also knocking its head off in 5th all the way down the straight which was a little unnerving...but kept my foot into it enough to get a laptime
Great sutff on laying down a low 49 mate. All it needed was some bald semi comps.
Oh..and the lil 20 is now finally starting to get blow-by :(
more boost is needed to compensate for the boost that is hiding in the sump!
Bris, listen to Ben. This has worked for me over the years...
kinda.
Thats how much they sting your for locally. OS they are more like $1400
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
