I'm using the stock mani but it has a very good welding job done on it and has a collector with a 38ml gate and screamer on it. I have a bleed valve ,z32 afm with big pod,oil catch tank,fmic,full 3inch exhaust, gtr injectors and reststor pack,new yellow jacket coil packs, power FC with controller plus have just scored a aftermarket clutch and lightened flywheel and am thinking of cams and if needed a oil cooler..
Edited by Co-stan-za
I went backwards with Apexi 260/8.8mm cams so removed them after hours on the dyno and some disappointing results from the test drive. They did sound tough though :) So I would hold off on cams and go with the oil cooler.
The TD06-20G and RB20 will never have the response of some of the other combos, but it will be a reliable grunter able to run 12.2-12.8sec qtr miles so still a respectably quick car. I would prefer it over the other options you have but the real test should be for you to go for a drive or get a steer of a car with a similar setup to see if that's the direction you really want to run.
1329105757[/url]' post='6232234']
I have been in a sr with 3071 and did like but that thing needed around 20 psi to start getting on song and I have owned a td05-20g so as i liked the feel of that I decided to go the td06 l2 20g 8cm and went and picked it up yesterday. Will be going in next week,only thing is I'm trying to get a t3 to 3 bolt trust style flange adaptor for my mani as I dont have a grand for greddy or good aftermarket mani..will post up dyno chart next week.
1329448924[/url]' post='6239209']
Let us know how u go mate as I've always wondered the dif between the 05 and 06 7cm vs the 8 cm 06.Cheers
nice!!!
did you hear?
you've been approved.
For what?
As for living the dream? I wish! I hate having to travel to earn a dollar in my industry. In the last 10 years I have been OS for 4-5 years of it in countries most people would be happy to holiday in for 10days :( Living the dream would be a job, a house and my cars. Not a career, bad health and impulsive automotive buys to make up for everything being pretty shitty :)
Really depends on funds. I really need to stop buying mid price shit boxes and stop the cash burn on cars. At the moment I am thinking E30 EVO III M3, and a Viper of C4 ZR1. Love to get a ZO6 but need to get something I will flog off and think a Viper would be the way to go. Will keep the M3, and maybe the ZR1....but yeh. Will have to consider a cheapish car I can keep or a car I can flog for a small profit to help pay for a mancave. (which is the main reason for going OS with work...try and get some cash together because of stupi real estate prices)
i like the c4, which z06 where you looking at c5 or c6?
c5 zo6 seem to go for about the same as c4 zr1's, ($20.000 to $30.000) so depends on which one you like. :)
vipers don't seem to be easy to sell in aus, but you can always drive it till you sell it.
have you seen these?
http://www.shelbyautos.com/vehicles.asp
Well, my motto is money is only important if you don't die tomorrow! :whistling:
So The E30 is a pretty much sure thing. If I can get a Sagaris as RHD car into the US and it is counted as a private import with regards to bringing it back to Aus then that may be the go. But odds are it will be an E30 to keep and perhaps something else as something to try and import and turn a profit...so dont really care what it is as long as its fun to drive/own for 12 months in the US and doesnt cost a fortune in parts when I break it at whatever tracks I get to...of course this is all assuming i can keep my Russian bride employed and bringing in the coin :thumbsup:
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
