No noise day = PIARC day?
Yep! :)
The thing was maxxing out its GTR injectors with a belly full of corn syrup so not a lot of time was spent trying to get a result, just a few dyno pulls to see how it behaved. So its hardly an exhaustive test and tune with E85, its just a little disappointing that other cars fill up with E85, load more fuel and ignition and they readily show signs of making more power vs my car that seems a little more stubborn.
Fark Garret fluff..i have a an army of Mitsubushi turbos that will go on before I soften up and go roller girl bearing
Just need to sell a few more parts so that I can play with the R32 whilst rebuilding the Sierra :)
We knew it was going to happen, just wanted to try the corn juice to see if the engine liked it and whether it helped its tendency to ping. I think if nothing else this test has told me there is nothing magic about E85 and if you are out of compressor flow then you are out of compressor flow and E85 will only give you a few more killerwasps :(
I have not bothered as the 20G with a 10cm housing was too big for an RB20. So I am betting a 25G would be rather ordinary on a 20. Would probably make a good number, but would make less than 200rwkws at 5,200rpm :( If i had a freshly built RB20 that I knew was well balanced and had a good oiling system it would be probably a decent enough thing to spin up between 5,500-9,000rpm.
If I can sell some of my fluff laying around I could quite possible give the T67-25G a nudge. The crime will be is if I run it with E85 and the 10cm housing I will instantly losing $300-500 as it is brand new. Think I will have enough trouble selling them with the Kando things running around but not fussed. Some of the gear I dont really want to sell, just need to move enough to clear up some funds for further work on the R32 and Cossie rebuild
The 25G wheel is 15% bigger than the 20G wheel, so with the little 69.7 mm stroke of the RB20 and 8.5:1 compression, like i posted above I dont see the RB20 doing a bang up job of getting the most out of the T67.
That's why I grabbed the 73HTA wheel, it is only 7% bigger but is lighter so stands a chance of spooling as well, if not better than the 20G wheel.
But for now I have decided I am going to shelve the plans for the 73 HTA and see if the lil std motor can handle the corn syrup and the power it makes with the 20G for a few track days.
I figure 306rwkws is a decent enough step from the power I was previously running and now getting into the area where I am less confident about how well a std engine with at least 60,000kms (i have put those 60,000kms on the wrecker engine) will do with that sort of grunt, boost and revs
I'd say its the turbo. they are only a 450hp turbo arn't they?
The way the boost trails off means the engine is taking more air than the turbo can produce. If you have a smart enough boost controller you can get around it. But the turbo will hate life
Edited by sav man
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
