ok, now Ive had my M35 for a month or so im looking at mods to do to it,
getting the TV tuner soon, at same time I will put a decent alarm/imobalizer on it and change to english,
after that im not sure where to go...
its got nismo suspension,
Nismo catback exuast,
Nismo Dash,
is it worth looking into doing the turbo to cat?
ECU? I heard Mines does one aswell as dolphin does one.... which is best bang for buck?
just wondering what else others have done to there M35's that is well worth the change...
Edited by whitestag
https://www.sau.com.au/forums/topic/330637-where-to-start/
Exhaust - dump pipe, probably best off waiting until you replace the turbo with a highflow :( They have a tendency to go after 100,000km's, in Japan I believe they replace them during that service. It's not all bad though as a highflow pulls like a freight train and is going to last a lot longer due to getting rid of the ceramic turbine. Besides with the stock turbo I doubt you are going to find remarkable performance upgrades from just an upgraded dump pipe alone.
ECU, so far in the country that we know of the Nismo & Impul aftermarket ecu upgrades have been tried and tested in the AR-X. From the opinions and stats that have been provided the Nismo seems like the choice of the two. Keeping in mind that no ECU from Japan is going to be tuned for 98RON and for all possible modifications, probably not going to make a huge difference but...?
Silver Auto Service are currently developing a remap system that will be done with live runs on the dyno, however the tool they need to do it is currently in Korea and they cannot confirm when the tool will arrive. Long story but as soon as there is an update someone will post something on the forum.
Aside from Mine's, Dolphin, Impul & Nismo there are also aftermarket ecu's available from G-Zone, DMY Racing.
https://www.sau.com.au/forums/topic/330637-where-to-start/#findComment-5370246
The dump pipe and in particular will make a big difference as there is a massive Cat in the stock one and the 3 inch exhaust will help give a little more in performance. More so in the mid range and a little in the higher revs but the ECu limits the turbo at the upper end of the rev range so there is less benefit there.
ECU's: the Jury is still out as we have more testing to do. Will also depend on your goal of performance gain.
Plenum Spacer will give a small gain in low end power and help fuel economy through increasing inlet runners and reducing the intake temps through the plenum. Plenum Spacer
Swaybars make a big improvement on the ARX, nor sure on the RX.
Brake upgrade: R32 Caliper upgrade. This is a big improvement on the stock from brakes. Brembo's are an option but a little more expensive.
Cheers
Andy
https://www.sau.com.au/forums/topic/330637-where-to-start/#findComment-5370423
Exhaust - dump pipe, probably best off waiting until you replace the turbo with a highflow :down: They have a tendency to go after 100,000km's, in Japan I believe they replace them during that service. It's not all bad though as a highflow pulls like a freight train and is going to last a lot longer due to getting rid of the ceramic turbine. Besides with the stock turbo I doubt you are going to find remarkable performance upgrades from just an upgraded dump pipe alone.
Going to have to disagree with you on this one Stephen...
I believe the most beneficial thing you can do for the life of these turbo's, given their fragility; is to reduce the restriction of exhaust flow. The standard dump pipe is massively restrictive, both in pipe diameter and also, as Andy has said, it contains yet another catalytic converter.
To give you an idea of the restriction, the flange off the turbo exhaust housing is oval shaped, 105mm wide by 55mm high. Within 30mm the diameter is reduced to less than 55mm! A huge reduction in flow, in anybody's book!
This restriction manifests as a huge heat load for the turbo to deal with. Replace this with a free flowing dump pipe, a high flow catalytic converter and a well designed 3" exhaust, and you will almost certainly extend the life of the factory turbo.
I currently have ONLY the group buy dump pipe on my car, with a 2 1/2" compliance cat (unknown quality) and the full factory exhaust (teamed with a K&N air filter). The difference made by this simple addition of the dump pipe is simply amazing! The car has a much deeper note, and the response of the turbo is much quicker and the reduced throttle required at any speed is easily noticeable. So large was the improvement, that I am presently planning to replace only the cat (with a 3" high flow) and running 3" mandrel bent to the front of the factory 2 1/2" muffler with a tapered reducer. I believe the hot gasses will have cooled enough in that distance it shouldn't present a very large restriction (given that cooling gasses shrink).That way I can keep the factory silence. It will be backed up with back pressure testing to see whether it actually needs a full 3" system. Fortunately, I have the time to waste, to see if I can save a few dollars.
All of this is just one man's opinion, of course. Good luck Whitestag, the guys you're asking have plenty of experience and are an excellent resource.
Cheers, Dale.
Edited by Daleo
https://www.sau.com.au/forums/topic/330637-where-to-start/#findComment-5370758
I would have to say the rest of your exhaust should be a priority.
You already have the Nismo cat-back (which one? Oval tip or twin square tips?) so all you need is a dump/front pipe combo...
Now, who do I know that has made such a thing... :)
and a good quality, high flowing air filter element
Edited by iamhe77
https://www.sau.com.au/forums/topic/330637-where-to-start/#findComment-5370960
If you don't need constant access to the cavernous space in the rear of the car, you should make a rear strut brace one of your first mods: bang for buck, it is by far the most dramatic improvement for $ mods you will undertake...
https://www.sau.com.au/forums/topic/330637-where-to-start/#findComment-5371043
The problem with the M35 is there's no strut towers as such to brace off.
If you were really keen, you could build a roll hoop and tie it in to the floor and the rear seat belt mounts with a cross bar to triangulate. But it seems like a bit too much effort for a 1700kg car with all the fruit. I have seen braces that tie the subframe together and also the subframe mounts. Big advantage, you can't see any of it.
https://www.sau.com.au/forums/topic/330637-where-to-start/#findComment-5371150
sorry to hijack the thread but which ones fit the c34's?
r33, r34 or are they stagea specific?
https://www.sau.com.au/forums/topic/330637-where-to-start/#findComment-5371356
Good question: I bought mine of darrinspencer, and never asked the question, but I'm pretty sure they're Stag specific
https://www.sau.com.au/forums/topic/330637-where-to-start/#findComment-5371873
Hi Matt,
Only talking engine performance.....and a couple of points will probably give you a bit more longevity with your standard turbo as well.
As mentioned above and I will take it to the grave the single best improvement I have done on mine and completely noticable straight away was a decent dump pipe with a good high flow cat(not that I have one....at all :nyaanyaa: )
The next thing you should look at especially with the coming summer months is a decent FMIC. There are two out there...Blitz from Just jap and the HDI. Also look at putting a Nismo thermostat in....will save the top tank on your radiator.
From what I have heard the suction pipe is also a very good upgrade (fitting on to my car atm while it's off the road)
As far as ECU's go the best piggyback for our car's is probably the Greddy but you will need to find a good tuner. You will more than likely find that you standard ECU will still fight with it though. There is the F-con but finding a tuner to do it is a problem...BD4's don't do it anymore...spoke to the guy yesterday. As for a replacement ECU, the Mines ECU....if you can source it go for it.....I've tried but to no avail....even if you get it how do you tune it? If you can get a Nismo or Impul it is probably the best bolt on upgrade and again you notice the difference straight away. Oh and if SAS ever get the reader unit back that would without a doubt be the best option as you will be able to tune the standard ECU.
As far as turbo's go Scott's is probably one of the best working upgrades. Not saying that I have given up on my turbo setup either....I just have a few more hoops to just through yet. Both of us have had our own headache's with our setups but I can tell you first hand Scott's goes like shit off a stick straight out of the whole basically no lag....oh and not saying mine doesn't go hard either......the Mexicans are just a bit ahead of us with development ATM :P
BTW the standard turbo will probably only ever get you about 180KW's ATW's....tops.
Edited by Jetwreck
https://www.sau.com.au/forums/topic/330637-where-to-start/#findComment-5371914
Thanks for all the info, I will start work on a dump pipe, Cat? who needs a cat.... never liked cats they always in the way lol.
so you running standard radiator? still good in summer?
running a V35 manual radiator....bit wider and no tran's cooler tank.....I run an additional 2 transcoolers though.
https://www.sau.com.au/forums/topic/330637-where-to-start/#findComment-5372067
Mishimoto radiator here. Overkill compared to the 14mm stock one.
You would be interested to know Craig, the car absolutely flies at take-off now the tuner leaned the acc enrichment. Get an Emanage onto that nismo. :P
https://www.sau.com.au/forums/topic/330637-where-to-start/#findComment-5373071
Rofl about the Mexicans Craig. :)
I think the F-Con Pro (V Pro) would be a nice way to go in the ecu department and thankfully, there is someone in Sydney than can tune them and more importantly, tune them well. I can't remember off top of my head but they are in Marrickville and tuned my mates R34 with an F-Con V Pro and on top of that, a V Cam setup. Downside is the ecu's are one of the most expensive to buy. Even used it fetches some coins as one came up for sale a few weeks ago in Yahoo. The workshop also charges my friend 1600 bucks for the tune from scratch. Obviously that included the V Cam tuning as well so it would be cheaper just to tune the ecu.
Bloody hell, my memory is terrible today!
https://www.sau.com.au/forums/topic/330637-where-to-start/#findComment-5388769
I have a question. Even with a Nismo or Impul of Mines ecu, how tunable would they be? Or is it they are more compliant with a piggy back ecu such as an eManage Ultimate.
The Nismo, Impul, Mine's, G-Zone, KS etc ECUs are all re-maps of a standard ECU.
I would not think they would be re-tunable here unless you had an acceptable "reader".
Perhaps if one was taken apart...
https://www.sau.com.au/forums/topic/330637-where-to-start/#findComment-5388793
I think the best bet at the moment is to get a generic G-Zone/Nismo remap and run an Emanage ultimate or F-con pro for adjustment to suit our mods, fuel and climate. The Emanage is certainly the cheaper and easier option.
With a quicker reaction time I could have got into the 12's at Calder last weekend (I hit speed cut 3/4 way down the track too), not bad for a 2 ton car. :)
https://www.sau.com.au/forums/topic/330637-where-to-start/#findComment-5389022
    • I did end up getting it sorted, as GTSBoy said, there was a corroded connection and wire that needed to be replaced. I ended up taking out the light assembly, giving everything a good clean and re-soldered the old joints, and it came out good.
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
