  • Replies 42
help, I went to get grocerys and when I went to drive home, started the stag up,,, it idled really low and was fighting not to stall, then cleared up but wont go over like 2.3k or so,, just like its hitting limiter,, really nead help guys
AFM.
Nm35 Died Mid Flight, anyone had this? - its tricky
We don't get offended since we have been making more power for so long that we are genuinely happy every time you guys crack a little more power than stock...... :P
AFM = Air Flow Meter
MAF = Mass Air Flow
AFM = MAF
..ahem..a little more power? i think scotty and jetwreck have both achieved a bit more than a little :)
I'm surprised no-one has bitten on this comment, as I run into all the time I'll end my rant now :/
Everyone was a bit slow to bite there Bis.
Since generalisations were being thrown around I thought.....what the hey. :/
really!....thanks for that!
Sorry Jet that was being directed at whitestag's query. (I'm pretty sure you are saying derr)
lol.....I did write a couple of responses.....but there is no real come back.
Your right....heaps of parts straight off the shelf to build a decent tractor motor....sorry RB.....hey after 20-30 years of the motor being on the market getting 270 AWKW's reliably out of one of them without cracking the motor open and with the same turbo housings should be easy aye!
lol.....how did we get here from AFM :/
Edited by Jetwreck
Yeah, but isn't that almost what Scotty is doing anyway?
Funny thing but AWKW and RWKW readings are almost always identical unless there is wheel spin. Sure people add 10kw or so to their figures but I take that with a grain of salt...in fact all dyno numbers as well.
The R33 is in RWKW cos it only has one diff and doesn't struggle for traction (in a straight line at least). Obviously the stagea was missing its front driveshaft for the dyno runs. It grips up fine with it back in.
all good, went over to northshore,, they checked it and replaced the MAF and all good,,, ready for some spirited driving again...
Thanks for all your help everyone.
now onto that dump pipe..
Edited by whitestag
some of the C34 guys get a little confused.....I give you a heads up as they don't quite get it :( ......our car is 98% different to the C34! So when you hear the line "Well on my C34......" more than likely they are completely wrong with the assessment!
Sorry in advance if I have offended any C34 owners :P
98% different hey?
I was going to say: "Well on my SR20......" I was right anyway, despite the fact that I own a 4 cylinder. BAHAHhahahaha.
AND it still ended up being the AFM!
98% different hey?
:D what error code comes up and how do you get it with your SR20!
here's one for you.....the C34 has a shit load more in common with a R33, R34 yes?....or would you say the C34 has a lot more in common with a 350Z!
and congrats on the diagnosis........your a rocket scientist aye! :)
Edited by Jetwreck
I've got the factory MIL light on the SR20 fitted to the 1600. Never use it though.
I just plug in the nistune software and it tells me the fault codes. Pretty easy and highly recommended.
C34 has a motor in the front and so does the M35. Both are made by Nissan. Both have an AFM and by the sounds of it, have a limp home mode. That's enough commonality for me :bunny:
Rocket Scientist? Nah, just willing to help a nissan brother out...
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
    • 310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
    • The filter only filters down to a specific size. Add to that, the filter is AFTER the pump. So it means everything starts breaking your pump even if its being filtered out.
