Hi Fellas,
On my way home from work I gave my car a little squirt... and it ran fine...
I gave my car another squirt and the turbo didn't sound nearly as loud, the turbo was making a very different pitch and smoke was coming from around the turbo housing when I opened the bonnet.
The turbo still makes full boost, but the car isn't making the power it used to, and the turbo sound COMPLETELY different.
Not sure what it could be? I check all the pipes and stuff that was all fine....
If my turbo was blown it wouldn't be making boost?
Also, not when I hit it the car backfires sometimes under full load...
Has anyone ever experienced such symptoms, or has any idea what it might be?
Thanks.
https://www.sau.com.au/forums/topic/330678-i-think-my-turbo-has-died/
any unusual smoke from the exhaust.
have you pulled off the turbo inlet to check the turbine, see if it spins freely etc.
does the engine tick when you rev it with the bonnet up?
might just be a blown turbo >manifold gasket
If it's a stock turbo, its possible part of the ceramic exhaust wheel has chipped throwing off the balance of the wheel. If the turbo was completely blown, it would revert to being N/A, and you will definitely know powerwise (low compression N/A RB anyone?)
Check the cat hasn't melted/blocked up, and check for snapped studs on the manifold and turbo
Its an RB25/30 with a GT35r.
It's not the cat because I am running a straight pipe.
There has been no smoke from the exhaust at all, which makes it even more unusual....
When driving off boost and idling, the car sounds fine, it's only when it's under full load it start playing up....
Ill bull off the intake pipe when the car cools down to see if the wheel spins freely.
Thanks for your suggestions but, keep them coming!
leak in cooler or cooler piping, i had a leak in one of my joiners and it made the same boost, just felt like something was wrong
Could be the cooler piping, but then again, there was some outrageous smell coming from the turbo housing with smoke?
meh... just empty it and see how quickly it refills. then you can start worrying if its full pretty quickly
What's the "standard" if you'd like for how fast it should fill up?
I drive me car everyday to work, and quite a bit on the weekends, and I do push it quite a bit (that's what it is made for?)
Would it be bad, lets say, over 2 months for 600ml to fill up in the can?
Keep in mind its a performance vehicle running high pressure (RB25/30 with GT35R running at 23PSI)
That sounds like a decent amount of oil to fill a damn 600ml catch can in 8 weeks of driving on the street....
My car gets maybe 1mm of oil in the bottom of the catch can every time I service it which is around 6 months no matter how hard I drive it including mountain runs sitting at high RPM for 8 minutes up and down.
Curious to see what other people say :D
Edited by PM-R33
Some engines breath heavier then others. Especially at 23 psi with a 35r.
Not worth worrying about it.
Could put a drain back to the sump from the catch can.
Have u done any oil control mods when u built the motor?
One of the main issues with a bit of blow by is the fuel vapour breaking down the oil which then doesnt lubricate as it should.
So try not to miss an oil change or maybe even change it more frequently.
Obviously ur running forged pistons which when cold are even worse at sealing in compression. So let it warm up to operating temp, not just water temp but oil aswell, before u boost it at all.
    • Just bought a 2002 Stagea 250tRS VR-X Four AERO VQ25DET and spent the last two weekends cleaning and detailing it.. still have to do the wheels and the engine bay but the rest of it came up nice. Imported 2011 to S.A. and I'm the third owner since it was imported. I met the guy who brought it over, he went to Japan and picked out the car, bought it and ordered the wheels. He also gave me a list of stuff he did to the car with receipts. Coil overs (I have the original springs), 3" exhaust from the dump pipe back no cat, Custom dump pipe,(I have the original exhaust), Plenum spacer, 18" custom Work XSA wheels (need restoring, I've made a start..), Shift kit put through the 5 speed tiptronic auto, TV and menus/screens changed to english, Australian DTV tuner installed in rear. I've just had four new discs and new pads as well as all the fluids including the brake fluid replaced. I have all the receipts for the last 15 years and the import papers in a nice folder. Car looks great, goes like hell but fuel economy is not a thing lol.. pics next..
    • I ended up in this rut again lol, and used a shit ton of filler. One thing I can't understand is, even after using a big long block and going in long X pattern strokes, I always end up at bare metal again with no filler, and my repair started at one end of the door and now I've chased my tail to almost the other end of the door. I was thinking of hitting the panel with a hammer where it might be a high spot and making everything low then filling it, I did this on a small section on my other door by mistake and I think I fixed it lol. Is this a bad idea? The other thing is with guidecoat, whether it's the powder or spray, after I sand all the guide coat off, it doesn't reveal anything for me in terms of high spots and low spots and makes it especially hard when it's bare metal (at least in powdered form), am I doing something wrong here, or likely a high spot I keep going over and creating valleys? Lastly, stupid question but, is it possible that after sanding if I only sand over the filler area where I know to be a dent that it's impossible for me to dig into that dent? Unless there are other problems which I missed.
    • Yeah the rule of thumb with an LS is 7psi per 1000rpm. That is decidedly not enough at 6800rpm. I mainly looked for the scenarios where knock started to be picked up and it was later in the session when things were hotter, and oil was thinner, and the pressure was lower than it should be. (i.e very horrible). I am hoping with thicker oil (I was running Penrite ten tenths 10-40, the manual specifies 10-30) that does not leak that it's much improved at that time!!! I am using Project Mu Club Racer CR pads. I'm also using the Project Mu 335C fluid. The symptoms imply that it was fluid that boiled, but no bubbles seemed pretty weird to me when I bled it today. I want to try Castrol SRF as it has a much higher wet temp but, well, I have new Project Mu fluid lol... so I should at least use that. The pedal on track was really noticable. It went from basically normal feeling to instantly near-floor. The car did pull up as before, it was just very much nearly at the floor before the brakes engaged. At that point I pretty much decided the day was very done, it did *kinda* come back during that very slow cooldown lap into the pits. Felt perfectly fine driving home.
    • f**king around with the bro
