This was something I was considering for a long while. Things start to get rough at the 250 mark, braking distances multiply and its hard to tell the difference once your above 200. I advise caution... To the wind.
I dare say 3.9s out of the auto S13 might not cut the mustard. I am fairly sure you can get a touch under 3.7s in an S14 5MT, should be able to swap the crown and pinion over to our setups and retain our half shafts.
Me + this thread = epic lulz.
https://www.sau.com.au/forums/topic/331772-300km/page/2/#findComment-5416674
  • Replies 41
Hmm does the PFC controller really show speeds that high?
I remember when i went to the drags, i pulled a 112mph trap speed, but kept my foot buried for a bit afterwards, so the needle was well past 180, and the PFC only said a max of 179 :)
https://www.sau.com.au/forums/topic/331772-300km/page/2/#findComment-5418992
If someone organises a top speed run and it's not on salt flats (corrosion), I'm in.
You mean you want someone to do it with or your expecting someone to set this up legally? LOL
Either way Ill be in for both in due time.
https://www.sau.com.au/forums/topic/331772-300km/page/2/#findComment-5420710
Standing mile sounds like it would be a great fun event alright.
As was already said... R34 getrag and diff is the go. It will hold up to 800hp in a high speed sort of environment so long as your not doing big launches with semi slicks.
Meanwhile... on the autobarns in germany.
https://www.sau.com.au/forums/topic/331772-300km/page/2/#findComment-5420862
Done 312km/h... over 8k. R32GTR with 400rwkw and a dog box. Got there pretty quick!
Steve,
I was speaking to a few friends about doing this as an event, like the standing mile they have in the states.
We should get together and suss out some particulars.
I attended quite a few standing mile events in Florida over the last few years... There are allways a HUGE variety of cars and bikes turn up. I helped out on a record breaking 252+mph TT GT40 with nitrous.
The events are great!
It's a very easy going event, no one gets tooooo serious. It's just good fun. It's relativly easy on the vehicles, there's no crazy outlay for brakes or 16 pairs of tyres and it's technical enough to keep it interesting.
I'd like to see a 'cannonball run' standing mile event out in central Aus.
Cheers
Justin
https://www.sau.com.au/forums/topic/331772-300km/page/2/#findComment-5421775
i'm not sure if i still have it, but i used to have a motor magazine where they were at avalon airport or whatever it's called in victoria and they were testing out the top speed of a few cars. a lambo got to around 300kmh. they had some other exotics arranged but the person who was supposed to organise them wasn't able to deliver but they did have a 350kw r33 gtr turn up. test driver got it to close to 300kmh showing the car a small amount of mechanical sympathy. then the owner got in and managed to crack 300kmh.
if doing this on a public road you would want to make sure that the road is in very good condition and nice and smooth. bumps that feel like nothing at 100kmh will feel a lot bigger at 3 times that speed.
*wanders off to look through magazines for the article.
https://www.sau.com.au/forums/topic/331772-300km/page/2/#findComment-5421893
epic win I don't come read this for a few days and it's all about cops and robbers :D
hypothetically, as I'm a scientist :) *adjust labs coat* I may have some lovely nice stretches of smooth road far enough out of the way to be able to test top end speeds. Plus I just have to do it cuz this little skyline is just gunna!
yeh but getrag boxes cost a little too much for may taste (8k-10k correct?) and it's to be a 'streetable' car <-- under the impression getrag boxes are race application. Unless I can sell my current box (under 100k on it) for a decent amount but I'd need to retain the housing all the same...
but yesh, taller ratio sounds like the go, but I always wonder getting a s/h taller ratio diff is always suspect, as ya never know what sort of life it had before hand.
https://www.sau.com.au/forums/topic/331772-300km/page/2/#findComment-5423306
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
    • Decided for the first time ever I would tow my car TO the track day on the same working theory as bringing tools and spares "if I have it I wont need it, but if I leave it behind i will 100% need it" all setup and ready to go out and try these A050 for the first time First session showed I needed to stiffen up the dampers a touch but still managed a few 1:21's without much effort. things were looking good. Came in a dropped the tyres down  to 26/28 as they had gotten to 35/33C from 22C cold The first lap of session two I managed to drop into 1:20's. Then in the second lap into the second session. Coming into T3 and I suddenly lost brake pedal followed by some huge rear end vibrations and scraping sounds. Got it back into the pits after session ended and found this. in the attached video, all of the wobble is in the hub its self, wheel is mint, and bearing feels tight. lKXLqpd - Imgur.mp4   Deciding it was a bent spindle I tried to find bearing/hub assembly locally but was unsuccessful so it was loaded back onto the trailer i luckily brought it on to drag it back home
    • 1.05 you’ve gotta let it breath
    • You have to continuously fill it to avoid dry running. Personally the transmissions I've serviced have never been bad enough to justify doing this because it is definitely a pretty complicated and somewhat risky procedure compared to simply draining the pan, measuring what came out, then refilling with the exact same amount.
