hey mate,
i have nankang ns2's on my r34 gtt, on the rear i have 265/35/r18's on 10" rims which i was told by the shop (tyrepower newcastle) should be at 40psi, on the front i have 235/40/r18's on 9" rims which apparently are supposed to be at 38psi.
i'm guessing the difference in pressure has something to do with the differing height, not sure, but the pressures have suited me okay.
the back is a handful in the rain though
https://www.sau.com.au/forums/topic/332257-tyre-pressure/#findComment-5389857
^ a 235/40 and a 265/35 have the same height of sidewall.
ahh ok, what do the 35 and 40 refer to then?
You all realise your tyre pressure will rise a few PSI after driving when the tyres have heat up...
and even more for a track day or drags, or on a hot day or cold, or day and night. it'd hard to allow for all conditions tho.
back in my karting days we ran roughly 13 psi, but we'd adjust it till there was a 2 psi difference between hot and cold to find the ideal setup for the day
https://www.sau.com.au/forums/topic/332257-tyre-pressure/#findComment-5391526
It is the height of the tyre sidewall as a percentage of the width. ie. aspect ratio.
265/40 would be a higher sidewall than 235/40. thats why the common size is 265/35. keeping the rolling diameter similar across the 18" range. u see?
https://www.sau.com.au/forums/topic/332257-tyre-pressure/#findComment-5391698
i do, thanks mate, i'm still on the steep side of the learning curve lol
https://www.sau.com.au/forums/topic/332257-tyre-pressure/#findComment-5391702
My new tyre pressure monitoring system can see anything from 33psi to 39psi depending on weather / tyre temperature.
During warmer weather it was closer to 36 - 39psi.
https://www.sau.com.au/forums/topic/332257-tyre-pressure/#findComment-5392188
before this thread gets out of hand with people asking what pressure they have for their tyre size (including myself!)
how much does a couple of psi matter? ok, so if we imagine the pressure is meant to be 40psi, for ease of numbers, and it runs at 38 psi. that's a difference of 5%, which would make fk all difference compared to other parameters, like temp, speed, cornering and driving style
and more importantly, how much does it vary between companies? because i'd imagine each company builds to it's own spec, which might vary by a few psi anyways
as a side note, my r34 was bought and after some dramatic events i checked the tyre pressure, it was 26psi, it was after that my worries about the prior owner began...
https://www.sau.com.au/forums/topic/332257-tyre-pressure/#findComment-5396356
There is no one answer to this question. Ideally you want to run a tyre pressure that balances the car and feels good when you drive it. Typically tyres heat up and expand when you drive, so if you stand on the throttle at every set of lights i'd expect the rear tyres to heat up a little bit, however its mostly the front tyres that heat up more than the rears because you have the load of the car thrown forward under braking and also the fronts are constantly working harder that the rears because the turn and slide (if only slightly). Also this is in theory what could happen, in reality it doesn't make a difference when you're stuck behind a bus.
Secondly, with a gtr, I personally think you should run all four tyres with the same pressure because otherwise it may trick the g sensor into thinking you've got wheelspin.
https://www.sau.com.au/forums/topic/332257-tyre-pressure/#findComment-5399113
Yea. I'm running 38psi "cold" (just driving from home to servo). I'm guessing it'll be around 40psi when hot?
Yep, pretty much and when the tyres have cooled down, it will go back to 38 psi.
Yes, true.
I just pump an all round 34 psi and seem fine.
:D WTF!
You got any pics of that, where did you get that?
https://www.sau.com.au/forums/topic/332257-tyre-pressure/#findComment-5400058
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
