k so thats a cheap option.. what about if i wanted to get rid of my key all together?
then u be wanting a system such as:
http://www.auto-hub.com/stardrive_push_start_ignition.html
RFID to allow access to car and enable ignition button...
do remember...google is your friend.
https://www.sau.com.au/forums/topic/332404-start-button/#findComment-5393255
the new swift has this factory option my gf has it on her car
you dont need the key to open it or start the car in the phyiscal barrell
it has touch buttons on the door that work if the key is in your pocket
and when you are in the car the barrett has a handle that turns as long as the key is in your pocket
the barrell has a backup key option as well in case the system fails or the remote has a flat battery
https://www.sau.com.au/forums/topic/332404-start-button/#findComment-5393280
lol I like this. Imagine all the corny lines you could use to start your car.
For some reason I can only think of Arny quotes too.
Yes!!!
"I'll be back..." - lock the car doors
"Why don't you let off some steam" - turbo timer set to 1 minute
"Chillout...dickwad" - engine off
"Cohaagen...give the people the air!" - engine start
"My CPU is a neuralnet processor...a learning computer" can't think of anything I just like this line :woot:
https://www.sau.com.au/forums/topic/332404-start-button/#findComment-5393353
Hmm how many HP is it worth??
but this the sort of thing u looking for?
http://cgi.ebay.com.au/LATEST-PIVOT-Engine...=item2a08bc121f
Wow since when did they get that cheap :worship:
I remember looking at them for like $100 from Japan. Might actually consider one for that bloody price!
https://www.sau.com.au/forums/topic/332404-start-button/#findComment-5394162
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
