I think 316 is the go, 5mm angle wont be breaking in a hurry and will never rust, not like zinc or gal. I wouldn't gusset it as this is supposed to be the weak point anyway.
Yeah, 316 is all we use.
So I recieved these in the mail from Wayne on Thursday, and fitted them Friday morning. They are a Whiteline 350Z Heavy Duty Swaybar Ball Link.
They replace this little fella;
The originals were still in ok condition; the boots were starting to perish a little, but still sealed. No free play, but not tight. So probably indicative of most examples fitted to local cars.
The Ball joint is more than twice the size of the original and should be able to take a hell of a lot more load, whilst still remaining quiet & maintenance free, unlike a race style aircraft or rose jointed link. As you can see, they came with neat little nylon shields to further protect the ball joint from stones, dirt etc.
I removed the rifling from the centres with a scalpel, and also cut them down to 10mm so they would fit neatly over the shaft hex, and not press against the ball joint dust shield.
They came with nyloc nuts, which I elected not to use; preferring to stay with the shouldered nuts used on the original links.
This decision was twofold;
1; Using the nylocs precludes the fitting of the dust shields, as you would need to put a spanner on the flats otherwise the shaft will turn as you try to do up the nyloc.
2; The originals were fine, and a little loctite will do the trick.
Fitted to the car;
Rolled the car up on some ramps, chocked front wheels, car in Park. Everything is accessible now.
I elected to remove the top mounts with the links attached and fit the new ones on the bench as space is limited. My top mounts were in perfect condition. The shafts are a bit longer than the originals, but do not cause any clearance issues under the car.
Once the mounts were bolted in and the sway bar was reattached, I locked up one side, ensuring the ball joints were at 90 deg angles as per the std links.
I then located the other to the swaybar and adjusted the turnbuckle until the swaybar was not preloaded in either direction NOTE *this must be done with the car on a flat, level surface* this was the n locked up.
All threads have a small amount of loctite 242 stick (low strength locking compound) just to be safe.
The original links are 110mm centre to centre, and the Whiteline links are 115mm fully wound in, with around 25mm of adjustment. They have an anodised billet turnbuckle which alows the user to allow for sway bar variance,and unload the sway bar at rest. I believe the greater length will reposition the swaybar closer to it's original alignment on lowered cars anyway.
So thats it; less than an hour fitted
I was fairly cynical going into this about the difference they would make with a Standard swaybar, but felt it was the best way to test definitively.
Bloody Hell!
At 60 km/h a sharp swerve in either direction ellicts instant response; you can feel the rear sway bar working faster than the front one, honestly feel like it's running a stiffer rear swaybar! There is obviously far less flexibility in these ball joints, as the vagueness just after turn in is completely gone, the car just dives in. I believe this will be even more pronounced with uprated swaybars.
Once fully loaded, they behave as normal; completely silent, no harshness, just like stock. But it definitely feels as if there is less roll and that the rear is reacting more quickly than the front.
I'm stunned at the difference these links made, for such a simple part, and I believe the adjustability may actually make life easier on the standard (under engineered) link top mounts, due to being able to reduce the angle of misalignment in lowered cars.
I'll be approaching Wayne very soon about a group buy, and he's assured me we'll have an extremely competitive price.
I'm happy to answer any questions you may have, and obviously, stay tuned for more developments
Fitted to the car;
Bloody Hell!
Third time lucky :rolleyes: don't know why the pics didn't appear, hopefully this time.
post-61153-0-23542400-1295966220_thumb.jpg post-61153-0-13853500-1295966252_thumb.jpg
post-61153-0-33698500-1295966279_thumb.jpg post-61153-0-82920400-1295966302_thumb.jpg
post-61153-0-73962600-1295966347_thumb.jpg post-61153-0-72279400-1295966370_thumb.jpg
I removed the rifling from the centres of the shields with a scalpel, and also cut them down to 10mm so they would fit neatly over the shaft hex, and not press against the ball joint dust shield.
post-61153-0-03174400-1295966404_thumb.jpg post-61153-0-39808100-1295966429_thumb.jpg
Fitted to the car;
post-61153-0-01869300-1295966461_thumb.jpg post-61153-0-71530900-1295966479_thumb.jpg post-61153-0-92259400-1295966509_thumb.jpg post-61153-0-73808500-1295973703_thumb.jpg
I then located the other to the swaybar and adjusted the turnbuckle until the swaybar was not preloaded in either direction NOTE *this must be done with the car on a flat, level surface* this was then locked up.
The original links are 110mm centre to centre, and the Whiteline links are 115mm fully wound in, with around 25mm of adjustment. They have an anodised billet turnbuckle with lock nuts and are left and right hand threaded which facilitates on car adjustment. This allows the user to allow for sway bar variance,and unload the sway bar at rest. I believe the greater length will reposition the swaybar closer to it's original alignment on lowered cars anyway.
So thats it; less than an hour fitted.
Bloody Hell!
I'm stunned at the difference these links made, for such a simple part, and I believe the adjustability may actually make life easier on the standard (under engineered) link top mounts, due to being able to reduce the angle of misalignment in lowered cars, and cars with adjustable bars.
I'm happy to answer any questions you may have, and obviously, stay tuned for more developments.
Cheers, Dale.
Edited by Daleo
Nice work Dale,
You said you thought that by the link being slightly longer it will position the link on a better angle to the mount. So what you are saying is that by lengthing the link it lowers the position of the end of the sway bar which moves the mounting hole on the sway bar further forward and thus in line with the mount? Sounds logical and may well reduce the stress on the mount.
Is this link you were supplied, the 350Z link?
Cheers
Andy
Nice work Dale,
Cheers
Andy
That's right Andy.:thumbsup:
Yes, the link is their 350z Heavy duty link;
http://www.whiteline.com.au/product_detail.php?part_number=KLC141
Group Buy price will be SIGNIFICANTLY better than Whiteline's retail price; they do not discount, to protect their dealers. The dealers however, CAN discount.:whistling:
im interested in the group buy of these
any chance of a front one too?? :)
Group Buy will be happening next month.:thumbsup:
Front is a little complicated, got one off Stephen's wreck I can use as a sample? Whiteline haven't seen anything like it. I've got a couple of ideas. Thinking about a profile cut block, with one of their ball joints threaded into it. Send me a price and I'll take one off your hands.
Cheers, Dale
Edited by Daleo
i have spares you can have for the group buy, mate.
PM me some details and ill post them to you. or feel free to come past on your way to/from work. you have my address still
No worries, I'll give you a call early next week mate.
Craig its amazing as to how much those air guitarist's remind me of you lol
your one Scattered man...
Problem is is that I have heard it about three times now and it's stuck in my head!!!!!pinch.gif
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
