Slightly embarrassing update to my post about the Heavy Duty Whiteline links...:blush:
Turns out the orange covers are not a dust cover at all; they're just for protection of the joint & threads in transit...
Red faced all round for me, but they were just so neat...:spank:
As you can see, they came with neat little nylon shields to further protect the ball joint from stones, dirt etc.
post-61153-0-73962600-1295966347_thumb.jpg post-61153-0-72279400-1295966370_thumb.jpg
I removed the rifling from the centres of the shields with a scalpel, and also cut them down to 10mm so they would fit neatly over the shaft hex, and not press against the ball joint dust shield.
post-61153-0-03174400-1295966404_thumb.jpg post-61153-0-39808100-1295966429_thumb.jpg
They came with nyloc nuts, which I elected not to use; preferring to stay with the shouldered nuts used on the original links.
This decision was twofold;
1; Using the nylocs precludes the fitting of the dust shields, as you would need to put a spanner on the flats otherwise the shaft will turn as you try to do up the nyloc.
Obviously without these in place, the hex on the threads is easily accessible so the nylocs included can be used.
Details next week about a group buy on these links.
Cheers, Dale.
Cheers, Dale.
I'de still put em on, especially seeing as thats exactly where mine snapped
very interested in this GB and hopefully some sway bars when my black POS gets back on the road.
Also interested in the links and bars.
Are the links going to be sold modified?
No worries, I'm on it guys, there'll be info in the next few days ok?
Modified, as in with more solid upper mounts? If so then yes, thats my intention, if people wish to have them.thumbsup.gif
Edited by Daleo
I actually meant modified as in cut to length ( I think you mentioned cutting the bolts in your install )
Not a big deal though from the sounds of it.
Did you mean that there is a chance of getting stronger mounts fabricated as part of the group by as well?
The Links are straight fit no need to cut anything Dale cut the plastic dust covers that were not actually ment to be fitted.
The guys are looking at making a stronger mount and we will leave it to them as there are many guys here with fabricating skills and they can make a few dollars if they want and make them to suite as these will only work on the Stagea so probably not worth us making them at this stage and gives more opportunity for some one else.
We do at times make heavier mounts mainly cars like Subaru but they fit allot of models so we can mass produce them easier. If some one does them in say the stainless described they will be a great long lasting upgrade we are curious to see what ends up made!
We are still at this stage looking for a way to fabricate the front links as they are something we have not seen before and very unsual but do not look like they would work that well so we hope we can arrange something.
We will keep you informed
AFAIK the Z33 and V35 rear swaybar mounts are the same as ours.
its the front that are unique to our car, and AWD models of the G35. hmm i should check in the states for my mounts
Not quite Iain.
The Link is Z33 & V35 but the Mount is Murano. (go figure) (I am not sure if they are the same as V35 but that is logical.
I have been running the upgraded front sway bar for 2 years on my car now and have not had any problem with the front Link. The most important thing is a solution for the rear Link and Mount and sounds like you guys are all over it.
Dale, I am in for the Mount when you make them.
Cheers
Andy
G'day guyz. I just got myself an ARX 2001 yesterday. Seems like the sway bar upgrade is inevidable, so count me in if it's about sway bars, links & mounts. One question though... From previous posts and comparing stock sway bar from my mate's v35 looks like rear sway bar on my ARX is identical to v35/z350. He ordered his aftermarket one from USA for about 150 incl. delivery. My question is why people buy Selby's rear bars for almost double the price? Sorry if the matter has been discussed befor and I missed it. Cheers.
G'day Skip, Congrats on the purchase mate. The 350z bar is NOT identical. It is 12.5mm narrower each side, or 1 inch narrower overall.
This places an unnecessary side load on the already under strength ball links & upper mounts.
This is the main reason behind paying "twice as much" for a custom made component that fits the car perfectly.
Also, in comparison to a 350z, the wagon carries a significant amount of extra weight up quite high; in the form of glass & steel, and most of the bars available do not allow for that. The Selby rear and my own group buy rear bar is 24mm adj; versus 20-22mm for the 350z style bars. Several suspension specialist consulted during my group buy agreed, and felt that using a smaller rear bar, would comprise the balance of the end result.
I believe Paramour may have his Whiteline bars fitted by now, and it should be very interesting to hear his feedback, as the whiteline kit uses a quite large front bar (32mm) & a small rear.
This may have been done to keep some of the understeer bias of the std car. Set up the right way, my group buy bars will actually four wheel drift controllably and even oversteer under power out of a corner now.
Whiteline did extensive on car data testing to arrive at their numbers, so I'm sure the end result will be great.
Hopefully this answers your questions, and everyones patience with me will be rewarded this week with some group buy information.
Cheers, Dale.
Edited by Daleo
Hello,
Fitment of the Whiteline sways has been pushed to this Friday. .. will be able to post not long after. Taking the Old Pacific Highway back to Sydney. banana.gif
Dale feel free to catch up to compare if you like. .
Jules
Hello,
Jules
No worries, hope it all goes well.
Just to let you know the Only U.S sway bars we know of are just like the OE factory bar and are hollow and just pressed flat ends thus why they are cheaper it is just tube steel where as Whitline are Solid spring steel and if you look at the steel price market at the moment you will understand the cost of the raw steel let alone then has to be bent , forge the ends and add the adjustment holes then powdercoated twice as we put an extra layer of corrosion clear for countries that snow and have allot of salt on the roads and makes the powdercoat last allot longer.
Edited by Whiteline
Hey guys i just imported my 2001 m35 250t rs four , 4wd turbo etc
and omg best wagon ever
please is there any chance of a list of al parts now available for the stagea , i am looking to do a full suspension upgrade using sway bars and the links in this thread also very keen on Daleos mounts if they ever came to be
also any other info on brake upgrade kits or anything will be appreciated
Edited by Sidius
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
