Slightly embarrassing update to my post about the Heavy Duty Whiteline links...:blush:
Turns out the orange covers are not a dust cover at all; they're just for protection of the joint & threads in transit...
Red faced all round for me, but they were just so neat...:spank:
As you can see, they came with neat little nylon shields to further protect the ball joint from stones, dirt etc.
post-61153-0-73962600-1295966347_thumb.jpg post-61153-0-72279400-1295966370_thumb.jpg
I removed the rifling from the centres of the shields with a scalpel, and also cut them down to 10mm so they would fit neatly over the shaft hex, and not press against the ball joint dust shield.
post-61153-0-03174400-1295966404_thumb.jpg post-61153-0-39808100-1295966429_thumb.jpg
They came with nyloc nuts, which I elected not to use; preferring to stay with the shouldered nuts used on the original links.
This decision was twofold;
1; Using the nylocs precludes the fitting of the dust shields, as you would need to put a spanner on the flats otherwise the shaft will turn as you try to do up the nyloc.
Obviously without these in place, the hex on the threads is easily accessible so the nylocs included can be used.
Details next week about a group buy on these links.
Cheers, Dale.
Cheers, Dale.
I'de still put em on, especially seeing as thats exactly where mine snapped
very interested in this GB and hopefully some sway bars when my black POS gets back on the road.
Also interested in the links and bars.
Are the links going to be sold modified?
No worries, I'm on it guys, there'll be info in the next few days ok?
Modified, as in with more solid upper mounts? If so then yes, thats my intention, if people wish to have them.thumbsup.gif
Edited by Daleo
I actually meant modified as in cut to length ( I think you mentioned cutting the bolts in your install )
Not a big deal though from the sounds of it.
Did you mean that there is a chance of getting stronger mounts fabricated as part of the group by as well?
The Links are straight fit no need to cut anything Dale cut the plastic dust covers that were not actually ment to be fitted.
The guys are looking at making a stronger mount and we will leave it to them as there are many guys here with fabricating skills and they can make a few dollars if they want and make them to suite as these will only work on the Stagea so probably not worth us making them at this stage and gives more opportunity for some one else.
We do at times make heavier mounts mainly cars like Subaru but they fit allot of models so we can mass produce them easier. If some one does them in say the stainless described they will be a great long lasting upgrade we are curious to see what ends up made!
We are still at this stage looking for a way to fabricate the front links as they are something we have not seen before and very unsual but do not look like they would work that well so we hope we can arrange something.
We will keep you informed
AFAIK the Z33 and V35 rear swaybar mounts are the same as ours.
its the front that are unique to our car, and AWD models of the G35. hmm i should check in the states for my mounts
Not quite Iain.
The Link is Z33 & V35 but the Mount is Murano. (go figure) (I am not sure if they are the same as V35 but that is logical.
I have been running the upgraded front sway bar for 2 years on my car now and have not had any problem with the front Link. The most important thing is a solution for the rear Link and Mount and sounds like you guys are all over it.
Dale, I am in for the Mount when you make them.
Cheers
Andy
G'day guyz. I just got myself an ARX 2001 yesterday. Seems like the sway bar upgrade is inevidable, so count me in if it's about sway bars, links & mounts. One question though... From previous posts and comparing stock sway bar from my mate's v35 looks like rear sway bar on my ARX is identical to v35/z350. He ordered his aftermarket one from USA for about 150 incl. delivery. My question is why people buy Selby's rear bars for almost double the price? Sorry if the matter has been discussed befor and I missed it. Cheers.
G'day Skip, Congrats on the purchase mate. The 350z bar is NOT identical. It is 12.5mm narrower each side, or 1 inch narrower overall.
This places an unnecessary side load on the already under strength ball links & upper mounts.
This is the main reason behind paying "twice as much" for a custom made component that fits the car perfectly.
Also, in comparison to a 350z, the wagon carries a significant amount of extra weight up quite high; in the form of glass & steel, and most of the bars available do not allow for that. The Selby rear and my own group buy rear bar is 24mm adj; versus 20-22mm for the 350z style bars. Several suspension specialist consulted during my group buy agreed, and felt that using a smaller rear bar, would comprise the balance of the end result.
I believe Paramour may have his Whiteline bars fitted by now, and it should be very interesting to hear his feedback, as the whiteline kit uses a quite large front bar (32mm) & a small rear.
This may have been done to keep some of the understeer bias of the std car. Set up the right way, my group buy bars will actually four wheel drift controllably and even oversteer under power out of a corner now.
Whiteline did extensive on car data testing to arrive at their numbers, so I'm sure the end result will be great.
Hopefully this answers your questions, and everyones patience with me will be rewarded this week with some group buy information.
Cheers, Dale.
Edited by Daleo
Hello,
Fitment of the Whiteline sways has been pushed to this Friday. .. will be able to post not long after. Taking the Old Pacific Highway back to Sydney. banana.gif
Dale feel free to catch up to compare if you like. .
Jules
Hello,
Jules
No worries, hope it all goes well.
Just to let you know the Only U.S sway bars we know of are just like the OE factory bar and are hollow and just pressed flat ends thus why they are cheaper it is just tube steel where as Whitline are Solid spring steel and if you look at the steel price market at the moment you will understand the cost of the raw steel let alone then has to be bent , forge the ends and add the adjustment holes then powdercoated twice as we put an extra layer of corrosion clear for countries that snow and have allot of salt on the roads and makes the powdercoat last allot longer.
Edited by Whiteline
Hey guys i just imported my 2001 m35 250t rs four , 4wd turbo etc
and omg best wagon ever
please is there any chance of a list of al parts now available for the stagea , i am looking to do a full suspension upgrade using sway bars and the links in this thread also very keen on Daleos mounts if they ever came to be
also any other info on brake upgrade kits or anything will be appreciated
Edited by Sidius
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
