yeah had organised to go to the midnight launch at jb.. not going anymore.. you can download a copy of Black ops on torrents.. i didnt bother as i don't have any chips in my consoles and i'm happy to wait..
ill be picking this up for ps3 at midnight then hopping on to play online !! if anyone wants to have a game tonight or tomorrow feel free to add me !!
my psn username is "boosted_r34gtt" happy playing people
nice, what store you picking it up from, knox has a premiere launch where they do all these activities before 12.
No activities people just standing in line waiting
lol ive been browsing through the eb website and i saw there midnight launch pics, theres pizza, dj's, rc car races and lan matches at the sydney store that is doing the premium launch. i also watched the black ops timer on the site for the last hour and i saw it get to zero. wasnt as cool as i though it would be.
EB will price match - they did it when i grabbed my copy of SC2.
So just go in with a brochure from a competitor and you'll be right.
They will kick up a stink about it (the guys i approached did at least), but they did it none the less and i was $30 better off :D
someone review the game - on PC, im not convinced it'll be worth it
yeh i always used to do this with GAME so i could get 5000 points on the card so i can save 30 bucks when i buy something.
They will kick up a stink about it (the guys i approached did at least), but they did it none the less and i was $30 better off :)
This is the problem, it used to be new COD - buy COD, Treyarch less great but passable.
Now I actually have to find someone that I can trust to have an informed opinion but is also willing to actually buy Black Ops which so far is none. No one that I know with an opinion on games that I respect is willing to shell out for Black Ops after the MW2 monster fail.
From the gameplay vids I am not convinced at all, in fact they are nearly all xbox and all with crappy lag spikes and auto-aim fail.
So far I have seen rage from installation failures, rage from server browser bugs and 'easier than MW2' like below. Also 'guns less accurate than MW2'.
i managed to get the game (pc version) last night at midnight launch and install. played multplayer for a cpl hours.. seems even easier than mw2 and is buggy as f**k.. i seem to get random lag spikes for no reason even though im getting 50 ping.. so far not overly impressed
Not a good start.
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
