post-53916-1281758531_thumb.jpgpost-53916-1281758462_thumb.jpg[attachmen
My story starts when i pulled my diff out to shim it, but i found my pinion gear is shagged. So im looking for another diff. My car is a r32 with a gts4 rear subframe its got gtr 6bolt axles etc..
What i would like to know if i buy an r32 gtr diff can i just change the drive shaft yoke from the gtr/gts4 yoke to just the normal 4 bolt??? Is the posible?
I get the feeling my diff is a viscous gts4 it is a 4.1 ratio and the owner before me changed the input flange to the 4bolt one, but never got the preload and backlash right so its destoryed itself?
any help would be mint
https://www.sau.com.au/forums/topic/332915-r32-diff-help/
got any pics of the diff centre? If it is 4.1 ratio it is gtr not gts4 (they are 4.4 ratio).
i guess they just got the backlash wrong when changing the cente to do that sort of damage. but a gtr pinion should not cost too much?
how many teeth on the pinion? you can always confirm the ratio by turning the tailshaft and counting the halfshaft turns
https://www.sau.com.au/forums/topic/332915-r32-diff-help/#findComment-5399099
The diff centre is a viscous im pretty sure, the pinion has 12 and the crown has 49 teeth.
yea i would like to just find a gear set and put my diff back together but not many people sell them seperate.
so what i was thinking ill just buy a gtr diff and change the input flange to the normal 4bolt flange like the one in my pictures, but is this possible??
If i went with the gtr diff id get rid of the viscous...
https://www.sau.com.au/forums/topic/332915-r32-diff-help/#findComment-5399290
That ratio is from a Stagea (= 4.083:1). GT-R is 9 (pinion) and 37 (crown wheel).
Get a replacement diff (GT-R, GTSt, Stagea, doesn't really matter), and swap the crown wheel onto your existing centre, and the pinion into your existing housing. That way, input and output bits will still match up. If you get a differential specialist to do it, they can set up the backlash correctly at the same time.
BTW, the ratio is generally stamped somewhere on the crown wheel ("teeth on c/w" : "teeth on pinion") - saves a heap of tooth counting!
https://www.sau.com.au/forums/topic/332915-r32-diff-help/#findComment-5399322
Thanks for the info haha i would have never guessed that!!!
The main thing i want to find out is if i get a r32 gtr mech diff can the input flange be swaped with the normal gtst 4 bolt flange? Because if it can it should be a easy bolt in and im better off with the mech diff then the viscous
https://www.sau.com.au/forums/topic/332915-r32-diff-help/#findComment-5399348
no its easier than that. As blind_elk said, just swap the internals of a diff (gtr if you want the mech centre) into your existing housing. that way you know everything bolts up fine.
so all you need is a 2nd hand gtr diff and someone who can assemble it properly.
BTW blind_elk...do you have the numbers for gtst and gts4 as well. this thread is a valuable reference now
https://www.sau.com.au/forums/topic/332915-r32-diff-help/#findComment-5399350
Duncan, I think the problem luxing is having is whether or not the output shafts will fit into the appropriate location in the diff centre, ie is the shaft of a GTSt the right diameter, length and spline configuration to mesh with the diff centre. And I don't know that, which is why I suggested to just swap the gears themselves. (If I had done the whole assembly swap with my Stagea diff into the R32, I probably would have lost any LSD function, because it seemed that the Stagea had an open rear diff)
GTS4 is 35:8 = 4.375.
GTSt is 4.363? That would make it 48:11.
https://www.sau.com.au/forums/topic/332915-r32-diff-help/#findComment-5399404
All i want to know if i can change the input flanges/yokes. I want to take the 4wd input flange off the gtr diff and just bolt on my gtst input flange(normal 4 bolt)
Will it work are the splines the same? Will the spacing change?
the picture is the gtr input flange
https://www.sau.com.au/forums/topic/332915-r32-diff-help/#findComment-5399440
    • Kinkstah, no, coilovers aren't illegal, especially as a bolt straight in. The illegal part will be if they're altering suspension geometry beyond factory limits, or the ride height is not legal.   Sounds like the blue slipper just didn't want to deal with any later possibility of mods appearing on the car.
    • The problem has always been that coilovers are able to be adjusted, almost at any time, to be too low. Most people who ever get/got defected for/with coilovers were actually afoul of the minimum ride height rule. So the interpretation by cops/inspectors was always that it is pointless to allow numpty to raise his coilovers and get the car inspected/cleared, then just drop them back down again as soon as they get around the corner from the inspection station.  This led to the interpretation that they were illegal unless rendered such that they can't be adjusted (ie, collars welded to the body, that sort of thing). That may or may not have ever actually been the official line, but I'm pretty sure it's not considered to be a solution these days. Coilovers themselves fall under clause 3.2 b of that manual, because they are an "installation of a variable ride height system" and they don't fit the exclusions in that clause (which point to air springs and other pneumatic adjusters). So, as per previous statements, they require engineering cert to be legal on the road. Once you have such cert, provided you do not adjust them outside the height range covered by the cert, you are OK. Without, you have an unroadworthy vehicle.
    • Here E10 is the cheapest fuel. And general advice is to not use it unless you hate your car. From what I remember it clogs up stuff in the fuel system or injectors?  With US/Canada being E10 across the board, does that mean that all fuel there is terrible?
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW ) Edit: I checked. They aren't. https://www.nsw.gov.au/sites/default/files/2021-02/RMS-infosheet-light-vehicle-modifications-manual-suspension-and-ride-height.pdf
