Hey forum need expert opinions from you guys. My problem is my z32 is maxing out or so it would seem. I have a rb25det series 2 with gt35r and z32 with 3inch coupler going to a 4 to 3inch reducer to the intake of the turbo.
Now my problem is lately I have been noticing that my check engine light flashes everytime I get into boost, I also have a pfc and when I check readings with the pfc hand controller the only reading i see that looks like it could be a problem is the afm voltage at 4.5-5.1.
I found this strange as I figured 17psi should not be enough to cause a z32 to max out like that so I went over the wiring this weekend and noticed one of the grounds had came loose in the afm wiring. So i joined the two grounds of the z32 and connected them to the ground of the afm wiring and thought problem solved. Did not drive the car from then until just now and when going into boost the same check engne light flashed when going into boost in second gear and max boost was 16.5psi. Looked at the pfc hand controller and the afm voltage was showing 4.5 volts.
I never noticed this problem before and was wondering what it could be, cause as soon as I see the light I stop accelerating, so can not say for sure it is on continuosly when boosting. Does this seem normal to you guys or does afm seemd to be broken. I looked inside at the sensor wires and did not notice anything broken all seems normal. Can 16psi on a gt35r cause a z32 to max out?
Oh and when it happened for the first time and I checked the pfc hc at idle the voltage was jumping around from 0-5.1 . That is what prompted me to check the wiring and noticed one of the grounds were off.
Edited by Daboss
https://www.sau.com.au/forums/topic/333200-z32-maxed-out/
A Z32 AFM has resolution up to 500PS, which is a max theoretical of 373kw (in the real world is more like 350kw). Whenever you play with the AFM (cleaning, resoldering etc), it's a good idea to reset the ECU (don't know how it's done with PFCs) so it forgets everything it's learnt so far and starts from scratch.
https://www.sau.com.au/forums/topic/333200-z32-maxed-out/#findComment-5402352
Reset the pfc? Don't know bout that, resetting the pfc will erase everything it will then require a retune. The pfc has a warn function for the afm and I figure it is just reaching this point, and wanted to know why, if that was possible with the setup I have and if my car is in any danger. Highest knock reading is in the 30's afr is in the high 11's to 12 on full boost.
No real sign of knock and no excessive lean out so could this just be the jump in voltage at the onset of boost casue it happens when boost comes on at around 4-4500rpm and when I see it i remove my foot instantly so can not say if it is consisitent throught the rev range.
On the pfc what is the afm warn volatge? Casue as I did it this morning the max voltage read on the ofc was around 4.4 -4.5v and the light flashed.
https://www.sau.com.au/forums/topic/333200-z32-maxed-out/#findComment-5402390
pfc's dont learn so re setting wont do anything. whats the idle voltage like now that you fixed the wiring?
Since fixing the wiring at idle I am seeing around 1.3v but noticed when starting the car to move it out of the driveway this is before fixing the wiring it started with no afm voltage problems.
I then did the rewire after the startup and thats when I noticed the ground wire missing and reconnected it and didnt drive it from then until this morning cause I figured I had solved the problem. Which I didn't cause coming on to boost this morning it happened again.
https://www.sau.com.au/forums/topic/333200-z32-maxed-out/#findComment-5402393
To answer this simply, yes.
The 35R is more flow than the Z32 can read, which 16psi could be just enough with dense enough air. They are a fairly efficient turbo from what I know, dont need 30psi to make max power.
See your tuner about your issues, talk it over. You should be able to tinker with the values to give it a slightly broader spectrum (while making your points a little wider).
Or switch to MAP or Q45 :action-smiley-069:
https://www.sau.com.au/forums/topic/333200-z32-maxed-out/#findComment-5402447
Just a side point, the AFM is as far away from turbo intake as possible?
Funny stuff happens when its too close.
But ye, GT35, you'd be on/around the limits of the ole Z32.
And its nothing to do with boost pressure, its airflow.
https://www.sau.com.au/forums/topic/333200-z32-maxed-out/#findComment-5402476
Yea wish I could but have no competent tuners here, had a q45 but sold it cause of the size and heard the z32 could support more. Plus it was ok before just happened this weekend was boosting fine with it before, noticed problem checked founfd a loose ground connection, reconnected it and still the same problem. Is there a way to switch to map sensor with pfc?.
i had my rb25 gt35r upto 27psi and wasnt maxing out the z32, i have also had my rb25/30 combo upto around 23psi without maxing it out either, i have heard of the cheaper fake z32 afms to max out at alot less power than the genuine ones.
How do you tell if it is fake?
The airflow meter is in the corner were the stock intake box use to be and the turbo is in stock position.
https://www.sau.com.au/forums/topic/333200-z32-maxed-out/#findComment-5402489
Read this thread on how to tell a fake: http://www.skylinesaustralia.com/forums/Wr...ow-t332812.html
https://www.sau.com.au/forums/topic/333200-z32-maxed-out/#findComment-5402505
Don't PFC's also flash the engine light for knock?
So the light comes on as you start making boost, and continues to stay on until max boost? What are the boost and afm voltage readings when the light FIRST comes on.
https://www.sau.com.au/forums/topic/333200-z32-maxed-out/#findComment-5402877
I doubt you are maxing the AFM out with a gt35r although it can max one out, if you are only running 17psi you would have to be revving th esnot out of it before there was enough airflow to max it out. 4.5v is a fair way for 5.1v, as the airflow-voltage curve is exponensional eg the extra .6v is probably 80rwkw. Can you peak hold the value. Could it be the injectors maxing out, that will trigger an engine light, or knock as you already know.
https://www.sau.com.au/forums/topic/333200-z32-maxed-out/#findComment-5403144
hello
the Q45 specs are wrong and grossly miscalculated, even apexi caps them at 230rwkw from their powerfc documentation even though we all assume they are bigger and better (they arent). single z32 is good for around 360rwkw as per apexi specs and the powerfc will throw the engine light when you max it at 5.0v, not at 4.5v or anything less than 5v
as adriano said it wont be linear so unless you peak 5.1v on the AFM don't worry about maxing it out. and if you max it at 6500rpm its not a big deal, it just means you run out of load cells and stick on the same axis (map sensor style on full boost) so no loss
if you max a single Z32 your optoins are twin Z32 or map sensor dont bother with Q45 AFM, it is pointless and a waste of time and money
https://www.sau.com.au/forums/topic/333200-z32-maxed-out/#findComment-5403919
Nah it was the airflow meteras I did a peak hold and saw 5.1 plus when doing a sensor check the airflow value was going black and jumping around at idle from 0-5 volts.
Very true re peak hold.
The PFC handjob should be able to press the right key to highlight max values.
Can the OP confirm the AFM is hitting max voltage?
Yea I confirmed this with the handheld. With the peak hold and the sensor check.
the q45 can make more power then the z32 afm.
q45- has been known to goto 450rwkw
z32- should be good for around 350rwkw
have a look for yourself
http://www.paulr33.com/diagrams/airflow-meter-wiring.html
Ok will read thanks. I just read on this forum somewhere that the q45 would make less.
So far seems as if the problem has been solved a switched to a spare z32 I had and so far nomore warning light. Will monitor for the next few days and keep posted.
https://www.sau.com.au/forums/topic/333200-z32-maxed-out/#findComment-5403947
q45 has a much norrower range than the z32, as in 1v from both afm's will see the q45 flowing a lot more air, likewise 2v and probably 3v. but get closer to 4v and 5v and the z32 is flowing more air at the same voltage. z32 afm's support more peak power than q45s, just look at the standard pfc airflow maps for both and it becomes quiet obvious.
https://www.sau.com.au/forums/topic/333200-z32-maxed-out/#findComment-5404141
    • I mean it's a bit late to say "This won't have any tangible effect and it is not worth spending more than about three seconds on it, please just enjoy the car" But I said it anyway. Does the pod actually get any airflow in that position behind a bumper like that?
    • Hey guys - apologies for digging this up. Has this website been shutdown or is the outage temporary?
    • So, went shopping at Just Jap for things that might work for the intake  After some trial fitting there I ended up with a 3" x 45° silicone bend, a 3" x 300mm alloy straight, and a humped joiner, some minor trimming will be required to shorten some of the stuff, but nothing that is beyond my "ham fisted" skills The guy at Just Jap was most helpful as we had all sorts of joiners,  bends and stuff out trial fitting  Laying it out above the stuff in there it seems everything will fit nicely, and looking at it, it is probably the way I should have been looking at doing it from the beginning, probably..... In the end it is a front bar off job anyway to remove the original stuff behind the front bar that is taking up the required realestate needed, so maybe a Thursday or Friday job And because I'm a hopeless consumer, I grabbed some new steel wheel nuts, the current ones are a spline drive type with a "security" socket, that somehow someone keeps misplacing, the new ones are a basic black steel 17mm hex socket In other news: I just did my "final" tax return, I am now officially a old retired veteran pensioner, and I'm milking the system for all it's worth,  life is good
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
