  • Replies 204
duncan! where r u? we just beers in motel pool waiting for you n matt!
Delayed repsonse: - Glen Innes wasnt cold beer was crap lucky for Steve and I had a bottle of Bundy fully imported from Bathurst and at -no time did we feel the cold, (there was no freight on the bottle from Glen Innes to Warwick)
For all others we got to Warwick about 10ish gave the car a tub, found the track had a look see - a cruise or 2 - had no 4wd. Sorted that (fluid level sensor) - had another cruise or 2 - or about 30 laps plus. Bugger me canvas doesn't grip very good, so the Dunlop slicks are over it, A050s are back on for the sleepover - we will see what we can do tomorrow.
Our PB today (Powerbox) was a 1.24.2 top speed 199.84km per hour -great track, all having a ball, but I think after tomorrow might have to take back, that Wakefield is the hardest track on brakes and tyres
Duncan will be 5 seconds quicker tomorrow,had the full crew put new rear swaybar bushes in tonight and without being a dobber he wasnt rushing at all LOL beer time
Cheers
lol more beer than racing I think.
news from me is the car is running great, best is about 1.24.4 so far, will try a bit harder in the morning. puts me about 4th in sports cars but considering the mods on the car I'm very happy with that.
on the down side at least 1 turbo is dead so I'll be surprised if i last the full day tomorrow.
also stu has had a bastard of a day with his fuel pump, hopefully the bits from the cordless angle grinder will see him back out there and running well tomorrow
good to catch up with scooby, harry, noddy etc too.
good vids to post including noddy's 150klm/h+ drift at the back of the new section....can't do it till i get home tho.
ryan, you are missing out. this track rocks.
sau nsw road trip for here and lakeside mid next year.
I am kicking my self that I had too miss it. Fingers crossed I will be their next year, congrats on the time bugger about the turbo. Look fwd for the vids and more times.
I have cracked a rotor, killed the front left shock and the tires are definitely past their best.
Bugger, will you be able to run on sun? What times were you doing?
what a good weekend!
was good to see and meet the QLDers!
Harry, Noel, Callum and Noddy!
To the NSW guys - Duncan, Mitch, Matt, Stuart - thanks for all your help with everything - its great to have great people in the clubs to help you all out!
I ended up with a 1.37.5, with a first time of 1.43 - so not a bad result for a first time at a new track!
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
