Hey guys...
I am under the impression that R32 GTS-t runs a T28?
If so, would a T3 be a straight bolt on?
If so, how much boost can a T3 safely run?...
How much am I looking at for a T3?
How much for the conversion? Any other parts i need to plan for straight up?
Are there people on this forum that can help me do the conversion ourselves (safely and for a small fee ofcourse)...?
If none of the above can someone fill me in?
Thanks heaps...
Dave.
https://www.sau.com.au/forums/topic/33365-t3-turbo/
  • Replies 48
Dont go looking to get a turbo to run a certain boost figure, look for a turbo that supports the sort of cfm/power you are after.
Simply running 19ps doesnt equate to a quick car, with the wrong turbo it could easily equate to high inlet temps and a cooked engine.
So perhaps a better way of going about it is deciding the power you are after, and then what turbo best suits that level using the lowest possible boost, whilst still providing good response.
https://www.sau.com.au/forums/topic/33365-t3-turbo/#findComment-669327
I run 14 psi and its a 12 second car. 19psi means nothing. Its the flow and effeciency that counts.
The turbo from a R33 is not a T28
but its niether a T3, yet its a T3 bolt pattern!
confusing? it gets better, Nissan bought about 5 different series of these turbochargers, from garrett, but they are all ceramic, and Ball bearing (even the GTR ones) and all the R33 ones can have on the cover, 45v1, 45v2, or 45v3 or 45v4, and I have ever heard of 45v5. What that means? Dunno...
So the best way to refer to these turbos (by the way they are the biggest factory nissan turbo you can get, and pretty damn good performance too) is "a RB25DET turbo"....theres simply no better way to avoid problems.
I went to get a turbo from someone once and found myself looking at a T28 from a S14. I wasnt impressed heheh:P
My car is a VL with a RB25det with two of these turbos on custom manifolds. Boost hits like a mac truck at 3800rpm and gives awesome power delievery. I run 1 bar boost (approx, its actually set atm on 1.05kg/cm) and there is no problems with the ceramic wheels.
https://www.sau.com.au/forums/topic/33365-t3-turbo/#findComment-669754
R32 has a t3 turbo (fast spool up)
r33 has a t25 turbo (slow spool up)
s13, s14, and s15 has a t28 turbo (go up to 1.1 bar on a stock silvia.
You can use a t28 (uses a t3 flange). you have to get a differant outlet and mod the inlet, also add tap on the outlet to the intercooler. cheep upgrade.
https://www.sau.com.au/forums/topic/33365-t3-turbo/#findComment-669761
Hi stimps, well said, boost is irrelevant, air flow makes power, boost is a measurement of restriction to airflow. So more boost can mean that the engine is inefficient, not that it makes more power.
Only one correction on the Nissan turbos, Nissan owned the tooling and Garret made the turbos. But around R34 time Nissan tendered their turbo supply out for turbos to be made using the Nissan owned tooling. Hitachi won the tender, so the later turbos are actually made by Hitachi using Nissan tooling originally made for Nissan by Garrett.
Confusing, huh?
https://www.sau.com.au/forums/topic/33365-t3-turbo/#findComment-669849
Try here: http://www.skylinesaustralia.com/forums/sh...ead.php?t=30556
I bolted up a T3 to my 33's stock exhaust manifold etc. It's not quite a bolt-in affair, but it's about as close as you're going to get without buying a 'kit' for your car.
https://www.sau.com.au/forums/topic/33365-t3-turbo/#findComment-670200
Yeah I know you said 32, but the only step-by-step I have is for my R33, so that's what you get :P
I thought the RB20 exhaust manifold was the same as the RB25 one? The turbo and space to the strut tower etc is no doubt different but similar rules should apply.
You should be able to run 12s with the stocker if it's well tuned. 4Doorz on here has a FMIC and home-tuned PFC on his 33 and he broke into the 12s, I image with less torque but also less weight with a 32 you could do something similar. That said, a bigger turbo will make it far more easy :)
https://www.sau.com.au/forums/topic/33365-t3-turbo/#findComment-670636
Yeah... and the turbo's getting old too.... although i know it's still running perfect, it can't hurt to upgrade to a new one when i save some funds....
SO how much would i be looking at for a T04? then how much to install?...
who should i talk to? ADVAN?
https://www.sau.com.au/forums/topic/33365-t3-turbo/#findComment-670679
    • Agreed, I've never seen a 260RS specific manual. As GTSBoy said it will mostly be stagea other than the engine loom https://www.hgeconsulting.com.au/stageaservicemanual.pdf
    • You'lll likely have to make do with R33 GTR for engine/tranny stuff, and Stagea for the body. I don't know that there's even been an actual diagram seen in the wild.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
