"The Victorian government on Monday announced that householders in the capital would be able to hand-water gardens at any time and wash cars at home when water restrictions are eased to stage 2 for the first time in four years......
.....The restrictions will be eased from level 3a to level 2 from September 1 following heavy rains and water storage levels rising to almost 40 per cent, their highest level in almost three years."
Aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaw yeeeeeeeeeeeeeeeeeah.
https://www.sau.com.au/forums/topic/333963-are-the-rumours-true/
Nothing like an election coming up to get the sweeteners going, ah well, dumb bogans will still vote for them.
And WTF are they doing. 39.9% is not full, so it is rather irresponsible to lighten restrictions going into spring/summer...
Gah! Why would they ease water restrictions when we are still under 50%? Keeping them strict isn't too hard and it's helping fill the dams. If we go back to dry now then it's just going to damage the supply even more >_< The drought isn't over yet, no offence but I think the water would be more useful going on our crops and flora/fauna, rather than on our cars. Other than that hooray for more water, haven't seen this much at my fams property in over 10 years :D
those car washes are soo annoying first sign off sun and its an 11bty mile line, plus my car only gets in/out by about 1mm not very low friendly
plus the minute u get jibbed waiting for it to go from soap to rinse and vice versa dodgy kents
Agreed. 100%
I love washing my car but this is so stupid. Haven't they learnt anything from the droughts? What's wrong with continuing to save our water until we're atleast above 50%?! We've survived this long without watering shit and using grey water for the cars. The farmers would be pissed, and rightfully so.
i 2nd that
if we start washing cars etc from home, water use will go up and we are approaching summer so not such a good idea to lower the restrictions n like said were not above 50% yet
so keep saving the water guys
They are citing the new north-south pipeline and the F*****N extremely environmentally unfriendly desalination plant as the driving forces to allow the easing of restrictions.
As for me, I wash my car with a hose, water my garden, and water my lawn whenever I want - from my rainwater tank.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
