Hey mate
Just a bit of info. A while back when the diff in my R32 GTS-T was buggered, i looked at putting in a GTR diff. I didnt do it because apparently my diff is mounted with rubber mounts, while a gtr diff is solid mounted to the body. It was gunna be a lot of work to make it fit.
I was told that by a reputable workshop i take my car to for major works when i dont have time for it myself, hope that helps with that part....
its a easy 5 min swap to bolt the diff in, only need to use gtr outer hubs to make it all work. Workshop above has no idea.
  • 3 weeks later...
  • 3 months later...
Hi Rowdy,
Keen on R32 GTR body fuel cap/flap $30
BTW what colour ?
Cant PM you for some reason - maybe a full pmbox?
Cheers
Richard
0404 822 143
Shoulda looked at last post date damnit :(
Edited by Sinista32
I don't get on here anymore guys. Don't play with the car much these days.
My inbox was full and I have now emptied it.
I still have the pods and wiill get back to you XTRMTY
The 3 inch exhaust is still available.
I need to find the filler cap if I still have it. Pretty sure it was gunmetal and in good condition.
The oil pump is from a R32 GTR. I have no idea on year. Could do it for $80 posted.
I'm going to be selling the complete standard complied rolling shell soon and keep all of the good bit to refit into another car one day in the future. Won't have space to store a whole car soon. Will be looking for $5000 if you know anybody interested
hey dude, could you put up some pics of the headlight, im really only after the drivers side. . . maybe pm me when you do. . .
Cheers
Cheers
Just going to chuck them out mate. Not worth the hassle of posting photo's.
Edited by Rowdyr32
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
