I got a r33 gts............
I'll be buying a rb25det engine off justjap auto and putting it in my car......will it be a direct conversion...or are there any other things to change???
please advise me...
  • 2 months later...
Well the reason I said that was because when I was looking at doing it the engine package was $6-$7K...they're a lot more reasonable now..but it's still going to be at elast $2K to put it in.
The best option is to make an RB30DET out of your N/A engine
Great thread,
I too made the same mistake, that is buying a N/A skyline except mine is and R33 GTS. I am desparate to turbo my engine, however my local mechanic has told me that you cannot turbo the N/A....that is without ruining the engine! Reading this discussion has helped me see what can be done to the engine, with a low cost outlay and surprising gains, Thank you!
However I have a couple of questions,
How does the car now drive?
Is it as reliable as the N/A?
Are you sure that the modifications will not damage your engine?
cannot wait to get my project Turbo underway. :flamed: :flamed:
DanielWilliam: The car currently pulls harder than a stock GTS..this is with the crappy N/A exhaust still in place and running 6.5psi that is probably down to the higher compression :(
I've had the turbo on my car for about 50,000Ks now and nothing has been damaged in that time, from a reliability point of view I think that's great. If the tune is good, you should have no problems...just don't expect to be able to cram 14psi in and you'll be fine.
Great to here that Dan,
It has put to rest the only real concern I had after reading the thread (the longterm future of the engine).
Sounds like the car goes real hard compared to the N/A You had and I have now, mine came with a full Trust exhaust out of Japan which will hopefully complement the turbo well. All I have to do now is get the funds together now and I can start the project.
I guess it is like you said tuning is the difference the car will run well and hard with some dollars in the tuning side of the car!
I will keep you informed to how my conversion comes along. I have some pics of the car in its current state in my gallery.
Cheers mate
If anyone is interested I have everything you need to do this swap
Off an RB25DET
Exhaust manifold
Turbo (No play)
Oil/Water lines
std dump pipe
Inlet manifold/Plenum
Fuel Rail and injectors
If anyone is interested in these PM me and i can send you pics
reason why i am getting rid of them, upgraded to GReddy plenum and getting top mount turbo setup
That list could make my shopping very easy!
That stuff is exactly what I am shopping for at the moment, what sort of condition is the lot in? whats your location in relation to Newcastle? Also with the condition of the parts in mind what is your best price?
Cheers :P
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
