hey martin,
i checked the valve, i can push it with my thumb but its quite stiff....
jason
Yeh that's how mine is... Could you maybe take a photo of how you've plumbed up the bov, perhaps I'm picturing it wrong?
Hey mate,
Ok, I'll start with what I know for sure. Number 3 looks like the hose for the IAC valve. Which would explain why the bov did not work, because once the car is warmed up, that hose is blocked from the plenum and essentially does nothing. So that would work exactly as it would if you teed into any other pre-throttle body source.
Number 2 is a bit confusing. That looks like factory plumbing, but the bov should be plumbed into a source AFTER the throttle body. Plumbing it in before hand would serve no purpose, the bov would not function. So not sure why it's been done like that unless again, I can't see something. It's different to the RB25 setup so I can't compare.
Number 1 looks like it should work, but I can't see where the port below it is going so it may not. For science sake, try tapping into a line that you know is working AND gets it's vacuum source from after the throttle body. The fuel pressure reg for instance.
Hey Martin,
Yes the BOV is plumbed in using the factory piping/hoses. The small hose connects to one of the 3 metal pipes that bolt to the inlet pipe (that goves over the engine). On the other end is a hose that goes to the top of the manifold as shown. (number 2 connects to number 1 in the picture)
Just so I am sure when you guy's say AFTER the throttle body you mean on the inlet manifold side don't you. If so haven't I got it in the correct location?
Where does the RB25DET gets it vacum source for the BOV?
Jason
Edited by gts25
Hey Martin,
Jason
Oh I seeeee, fair enough. In that case the RB25 gets it's source from the exact same place, it just has a hose that goes directly there instead of being run underneath the crossover pipe. And yes, after throttle body meaning plenum side. Reason being is all the piping that is pre-throttle body is still going to be pressurized when you lift off the throttle, therefore holding the bov shut. You need a source that will be under vacuum when the throttle body closes, which is anything on the plenum side of the throttle body.
But, it sounds like you have it setup correctly. I still recommend trying to tee into a different source just to be sure (perhaps use a different length of hose instead of cutting anything so that it is easy to return to how it was if it doesn't work). If that doesn't work then I would suggest trying a different bov, one you know is working properly.
havent you forgotten to list pistons ?
you need low compression pistons, otherwise using the standard high compression pistons that NA's have will just F*&k ure engine VERY quickly.. although i have heard u CAN run a turbo, low boost (such as 7psi max) and still get a very quick car outta it without changin pistons.
Can't the headgasket just be changed to decrease compression and therefore run more boost? Thats what we used to do to n/a supras when we went turbo.......
Yes, you can use a thicker headgasket to lower the compression. Most people including myself don't though as it gives better response, more bottom end torque and saves alot of hassle of removing and re-fitting the head. So long as you can prevent the car from pinging with conservative boost, timing and good quality fuel, high compression won't cause problems.
Hi Martin,
I believe I have found the issue. The vacuum source on the inlet manifold that I am using for the bov (the charcoal canister port on the na setup) has some kind of restriction. I have a complete rb20det where I sourced all the turbo bits from and pushed a piece of wire into each port. On the BOV port the wire goes right into the manifold whereas on the other port the wire only goes in part way. There must be a valve of some sort.
Whilst I could go through the big task of swapping the top of the manifolds over, I really do not want to if I could get away with using another source for vacuum.
I had a quick look and don't know the best place I can use. I looked at the fuel pressure reg but this size of this port is smaller then I need.
Do you know (or anybody) where I could plumb it in? I thought about having a fitting made up that I could screw into where the factory boost gauge plumbs into (a t fitting that would allow me to plumb both the bov and boost guage). Could this work?
Jason
Edited by gts25
Done this turbo conversion last weekend with my rb20de.
Thought i should take some pics of the plugs on the side of the block for people as i dont think i have seen any on here yet.
for the oil return i used proflow part no. PFE841-12 3/4 NPT to Barb.
Also fuel economy is pretty much the same too.
if thats the case and no drilling is required on the 20de's that are thread taped from factory, how does one tell a rb20det long motor from a rb20de long motor ?
Edited by Dan_J
Hi guys, so I've just read through all 37 pages of this thread and from what I could saw, at the start there was a LOT of interest going on in favor of getting the conversion done. Towards the middle there was some doubt and some people were saying, JUST BUY A GTT or a car that already has a turbo in it!!! Saves a lot of headaches...
Now it is 2012 and this thread started wayyyyyy back.... Since R34 GTTs are almost the same price as 25GTs now, considering the drop in price for the parts for the conversion, do you think it is still worth it to do a turbo conversion for my R34 neo rb25de? I've actually spent a fair amount of time and money on the car already, and I know my car hasn't been thrashed around like most of the other R34 GTTs on the market.
I'm considering doing everything myself and getting the most BUDGET aka cheapest bits for my car, leaving the internals stock and getting a professional tune. How much rwkw am I looking at? And also how much will it cost as of may 2012?
Figures that I predict are from 100rwkw ---> 150-160rwkw?
Price about 1000-2000 dollars for parts and tune?
But I guess power isn't everything, I just want a really responsive car that has massive amount of torque lol.....
Car is pretty much stock as rock and I want to go for a sleeper look.....(personal reasons)
All help welcome =D
All help welcome =D
First of all, this is not the attitude to have going in to these sorts of jobs. It's a lot of work, and you need to be prepared for costs to get out of hand. Take your budget and triple it. Take your time frame for when you want it back on the road and triple it.
Secondly, your comment about most other 34 GTT's on the market being thrashed is also a bit naive. There's plenty of blokes like yourself who look after their cars.
My advice? Buy a GTT. It is honestly a hell of a lot easier. I went down the path of converting my GT to a GTT by simply swapping engines/gearbox/diff etc. etc. I've suffered for it ever since. I don't know if I would say I regret it, but I will tell you that the headaches are endless.
Edited by Hanaldo
Hanaldo: I understand where you're coming from, but from what I've read, some blokes are starting the job at 7.30pm and finishing the job at 5am the next morning, so apparently it's an 'easy' conversion, you just have to pick up the bits and pieces from this forum somewhere..... I want to experience the learning and go through what it's like to slowly and carefully put on a turbo and all the other bits and pieces then get it tuned, without the hassle of buying a GTT and not knowing how the engine is like, or what has been done to it. What I meant by budget, was BANG FOR BUCK. I don't want to be lazy and just sell my car and buy a turbo one, I like to do these conversion things, it sounds fun, but I'm not rich and I don't have all this extra money to be going into a car, so I would like a BANG FOR BUCK conversion....
Did you say you popped an RB25DET in? I don't want to do that, i'd rather buy a GTT but where's the fun in that? There is insurance, stamp duties, transfer fees, RWC, finding, selling, rego fees to pay that is involved with selling a skyline and buying another one. Instead I want to bolt a turbo on. Plus I've heard that the difference between a GT and a GTT is just brakes, ecu, and pistons. If i leave the pistons/brakes stock, all i'll need is a few bits and pieces and it should be fine, with the possibility of forged pistons later down the road for higher boost.
reason i said it was cheap and easy was because after reading the 37 pages, I get some people saying that they've done it for under 1.5k.
You're going about it the wrong way. You've just compared selling/buying a car, to turbocharging a motor that was never designed to be turbocharged. I realize I might come across as a prick in saying that, but I honestly don't think you're understanding what's involved here. You don't want to do the brakes later. The stock GT brakes are absolutely rubbish, I didn't want them on the stock NA motor let alone a turbocharged motor. Do the brakes and suspension first, then think about turbocharging it.
This also definitely isn't an easy conversion. I've read Gerg_31's build thread on here, he made building an RB26/30DE look ridiculously easy. It isn't. This conversion might be easy compared to other things, but it is by no means easy in reality. There's so many things that can go wrong. Don't pay attention to the ones that say it is cheap and easy to do, pay attention to the ones that are saying it isn't. You need to over budget not under budget, and trust me, it is so ridiculously easy to under budget. You've said you don't have a lot of money to be putting into the car, how much would you consider a lot of money?
With that all said, it's refreshing to see someone doing the research before saying they want to do something, so I commend you for that. I suggest you do more reading than just this thread though. Also talk to people who understand what is involved, people who have done the conversion, workshops who have done this sort of work.
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
