All reports say Achillies are pretty crappy. A bit more money will get a much better tyre.
If you bought the car for looks then buy a shitty tyre and hope it doesn't make the difference between a close miss and a hospital visit. But...I can tell you that a well washed Mazda SP23 would be more impressive to most girls.
If you bought the car for driving then you should get decent tyres. These start with something like a Kuhmo KU36 (fast wearing) or Federal 595SS (not exactly great), Bridgestone RE001 (a bit better), Sumitomo ZIII (my personal fav).
why the f**k would you name your tyres, which are basically shoes for what's effectively the feet of your car, after a hero whose weakness was his ankle.
they may as well have called it 'better than nothing' tyres. actually no. because that doesn't highlight it's one weakness is it's one sole (get it ) purpose.
You know what it's like.. it's like branding a condom 'AIDS.' It's the single most retarded thing I've heard all week.
thanks !
  • Like 2
hahaha Mazda SP23...
yeah well maybe the achilles aren't the stickest tyre out,
but they are not a track tyre and overall they compete okay for general day to day driving conditions.
I must admit they struggle to put my 260rwhp to the ground, but hey...
I got traction control and all that junk, I'm not sure if SP23's and older / cheaper cars have that option
so if thats your case, then spend huge amounts on sticky tyres LOL
lol
go crash into a tree cause your tyres are shit
thanks !
hahah well said!
But....
The cube came with achilles "sport" tyres on it, and they are actually pretty good. the poor old auto 1.3 cube kept up with the skylines thru the twisties on putty rd just fine with these tyres ;)
I would never have chosen to buy them, but they are actually pretty reasonable. 6/10. There are plenty of worse tyres that are more expensive
zebra is so hard!
dont be jealous because ur sh*tty car has like 100rwhp
and buying expensive tyres makes u feel better mate
:) haha
+1
I agree with Duncan, they are a pretty good tyre for the money
Nah, just can't be bothered arguing with someone who thinks he's right, and can make assumptions on other people's cars.
Edzakerry
lol at horsepower claim
ever note
VQ35DE - 206kw
1JZ-GTE - 206kw
so who else has a shitty car with 100hp
and besides 100hp car with good tyres = faster than 1000hp car with shit tyres
So Mr Gazza go drive a car with a sticky set of tyres on it then report back kthxbai
Dunno what everyones goin on about, I had Khumos, then toyos, now a set of Achillies, and the Achillies have worn the slowest, been the grippiest and the quietest?
YMMV obviously; I guess some people have good experiences with them, but it seems the majority have had bad experiences.
What khumos/ toyos
ever driven on a good tyre?
well in my opinion you guys are cashed up idoits then to waste cash on over rated tyre brands?
Because I've had Kumho KU31's on my 350z with quiet what some camber issues,
and the Achille tyres are alsum!
I've done 40,000 on them then got them rotated so i'm guessing i'll get near 70,000-80,0000 on a $260 19" 265 tyre...
Also taken the Zed around to the 260km mark and the things are still okay :)
and finally they are not noisey or any worse then the Kumho tyres....
sigh. just don't be anywhere near me when your "alsum" tyres let go.
Seems you have decided already. They might be adequate even quite good. Performance depends on the exact tyre model and size also.
I guess it comes down to personal opinion how much you want to spend on tyres vs performance. I've stated my minimum purchase requirements based on experience.
When I had 260rwhp I think I was on 595SS (255/40/17s) and they worked pretty well if you kept the pressure up at least 36psi.
Edited by simpletool
Simple answer: Why bother modifying your car and increasing its performance if you are going to skimp out on THE ONLY THING CONECTING THE CAR TO THE ROAD? Cheap tyres are for sh!t box dailys
Tyres are like any other car part.
You can buy cheap Ebay spec parts which will probably work ok, go pretty close to fitting properly and will last a while.
Or
You can buy a trusted big name part, these part will cost more because the manufaure spends money on things like R&D, product testing and quality control.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
