  • Replies 43
I know its good pricing and i know what the parts are worth, its more the labour i cant afford. Im considering pulling out the engine myself, getting them to build it and putting it back in myself to save a bit on labour.
So much to consider.
Im not actually sure what oil was in it because racepace changed it when they did the tune.
i wouldn't start thrashing my new money pit of an engine after a thousand ks but hey thats me maybe im soft lol i give them a lil longer, have personally seen a brand new 1000km run in engine destroy itself from bearing failure, (although it was a neanderthal 5l) its run in oil was a little too thin for the thrashing it was getting..
they are pretty easy to remove and strip, all the engine builders would need is the long motor that would save a heap of labor costs
They need to be driven hard to bed the rings in...being soft on them leads to a crap ring seal.
Plus with bearing and ring quality these days they a basically "run in" 10secs after they are started.
less than 1000kms its not even run in, what oil did you have in it when you were revving it that high?
^ um what? Motor is fine as soon as the rings are bed on the dyno.
Tune it up and off you go.
One of my motors, bed, 270rwkw tune done. Same for current motor, and countless other people i can think of.
Never a problem. None of this 1000kms business, old wives tale these days.
Take the motor out, pull it apart and then take it to the workshop, get them to do the very important and delicate assembly, then do the rest yourself. You should be able to knock a couple of grand off the price if you do that.
Also if you use the same parts you should be able to use the same tune with just a touch up also saving maybe $500-1000 in dyno time.
Was that actually confirmed or did the engine just shit itself for whatever reason and someone just guessed that was the cause?
Edited by Rolls
You'd have to say things like bad quality bearings, tolerances, machine work, contamination... plenty of areas :wacko:
Well the engine was built at home so what ever is wrong with it is most likely going to be my fault. Racepace has done nothing wrong, after the tune, when the car was running it was beautiful.
I was in the passenger seat and was watching the tacho as it came on boost in 3rd in the wet and it was around 9000rpm.
The oil pump was a brand new n1 unit so i hope that didnt fail.
It has a power fc and im not sure if it even has a rev limit. With the standard engine and ecu it would go a lil past 8000rpm but would sound like absolute shit and go nowhere but that was only tried once.
It can take only a a brief oil starvation at those revs to hot spot a bearing that will eventually fail, N1 or not. FC doesn't have any alternate maps it can kick in if it senses a problem, like some other ECU's. I'd recommend putting in a high capacity baffled sump on it when you rebuild, it's the only way you will have some insurance against oil starvations.
Hi-Octane Racing make one that has a slim profile so less chance of cracking it in our shitty roads, or just go a full dry set up, some great oz made ones and for cost of jap there are very competitive. From what I've read and heard from people it seems oil starvation on RB26's is not so an uncommon killer for stock bottom ends without some kind of extended sump when pushed hard or with g's.
well and truly run in, it would be run in after about 30 mins on a dyno.
We run-in and full tune many of our race engines and street engines in one dyno sitting (a full day), very common practice and eliminates incorrect run-in's by the customer.
my mistake guys i dont want to argue, i just thought they need longer.. learn something every day
as much as we dont want the engine to run with a stuffed bearing, you really need to start it up and see if it has oil pressure then turn it off straight away,
we have smashed the same 450kw engine 2 times, 1 at the drags in 4th gear across the line at 8500rpm and one doing 3rd gear burnout at 9000rpm, both were N1 oil pump failures,
had to bite the bullet and get a tomei after that.
so i wouldnt put it past a N1 oil pump failing on you but because the car was driven home im sure you would have noticed the knock then.
another possibility is after the machine work how well did you clean the block down and the head down? this is Extremely important and alot of 1st time builders over look it thinking the machine shop would have cleaned it correctly before giving it back.
when you drop the oil from the engine take a little sample and get it checked.
your much better off finding out exactly what caused it so you can prevent it from happening again.
there,s your problem. mine did the same. an n1 cant flow enough oil at 9k , it may have pressure but the flow drops and the bearing touches the carnk, game over. i went tomei.. the n1 will be ok, it just is not man enough at those revs ..sorry
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
