Well my electric seat is on an angle and I can only use it when it is flat, if I adjust or raise it it leans worse than a drunk on NYE.
After investigation nothing can be done to fix it with the exception of a new seat base frame so I am after one. . best source is a wrecked M35 with electric seats. .
So does anyone know where one is sitting at a wreckers. . before i make heaps of calls. .
Thanks
Jules
https://www.sau.com.au/forums/topic/334220-any-one-know-where-wrecked-m35-is/
Description:
NISSAN STAGEA M35, 2001 Rear Wheel Drive, 2500ccltr V6 Petrol 5sp Auto, 44000kms, WRECKING ALL PARTS AND PANELS., 0737156474 Seventeen Mile Rocks
for some reason Trading Post wont bring up the link but its on trading post, just search m35
Wicked, many thanks
Still waiting to see if mine is a write off. I'll keep you updated. I'm in Strathfield.
Is that write off still a goer ?
Please let us know i'll have your rear wing , back interior lift panel for jack kit.
and possibly a few other bits and piece :(
and possibly a few other bits and piece :)
Lift panel for jack - http://tinyurl.com/36a578v
Quote
You're a legend WTBN!
What a cool site.. ive ordered that jack lift panel.. as my dog chewed the corner off the other one!
have you ordered through these guys before ? I take it theyre a reputable source ?
Thanks
Keir
Quote
Thanks
Keir
Import Monster are fine to use Keir.
Sorry mate, mine's a keeper. Parts will be here in ten days.
Good luck in your search :P
Thats good news for you. ..
The QLD wrecker is getting back to me on their wrecked one. .
no radiators...
douches at the radiator shop are trying to tell me they dont make the tanks for these radiators yet because its "not old enough"
and are attempting to charge me $500 make a new ally top radiator tank or $1000 for a replacement aliminium rad...
sound a bit ridiculoius to you? does to me for a radiator!
Radiator? Don't go for a repair, upgrade it.
I went with a Race Radiators custom unit (uses a Griffin racing core) when my stockie died (spectacularly!), but being that you are not in Vic, perhaps look at a Blitz radiator for a Z33 and get your OEM transmission cooler put in the bottom.
A 16mm core is too small for a 1600kg+ wagon in an Australian summer IMO.
*** You WILL have to cut/modify your mounts to fit it though ***
Edited by iamhe77
Isnt the cap and inlet/outlet in the wrong spot on the 350z?
I have my old stockie here if you need race radiators to make one up off it, has yours failed Keir?
Inlet/Outlet should be the same although I do believe that the cap is in a different position.
Our radiator is the same as in the V35/G35 so any of those from the US or Japan will fit (again, with a little cutting of the supports).
Although shipping from the US for a radiator is a killer.
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
