Hi,
Just wondering if S1 and S2 autos are the same ?
Also the front diff does that just use engine oil ?
The transfer case, thats part of the gearbox so it uses transmission fluid right ?
How do you flush this transmission ?
Thanks in advance
Brendan
https://www.sau.com.au/forums/topic/334481-s1-and-s2-4wd-autos/
S1 auto is pretty much an R33 and earlier box.
S2 auto is an R34 tiptronic box, fair bit different to the S1.
Not sure on front diff.
Transfer case is seperate to the gearbox and uses its' own fluid, have a search and you'll find out what it is.
Just wondering if S1 and S2 autos are the same ? No
Also the front diff does that just use engine oil ? NO, GL5 85w-90 gear oil...where did you get that idea from ???
The transfer case, thats part of the gearbox so it uses transmission fluid right ? yes
How do you flush this transmission ? take it to an transmission shop for best results
Hi,
Get yourself an auto sump gasket kit and a 20L drum of (ideally) quality synthetic atf. You need 12 to 14L for the auto and you can use the rest for your attessa and power steering. Drain the sump and drop it (easier said then done - you will have to support the box and remove the rear mounting). You will only get betweeen 1 and 2 litres this way. Check that the new internal filter is exactly the same (otherwise the sump won't go back on) and if not either modify the new one to suit or clean the old one and put it back. Put 2L of fresh oil down the dip stick tube.
Then pull a hose off the trans oil cooler and run the engine until you have pumped out 2L into a container. Pour 2L of new oil down the dipstick tube and repeat until you get clean oil coming out. This will take 12 to 14L in total.
I'm totally confused with the s1 and s2 business.
Does that only apply to m35s or does it apply to c34's also ?
And what is this in reference too this thread?
and if its only for m35's and mine being a s1, why is it a 5 speed triptronic?
or is it 4 with overdrive?
Edited by PetroDola
This thread refers to S1 and S2 C34 1996 to 2000 not M35.
  • 2 months later...
Does anyone know what needs to be done to fit a s2 tip auto into an s1? So, other than box & steering wheel, what else (ecu?...)?
if your going to go to this level of f**king about just put in a 5 speed ;-) The tiptronic's not that cool.
Yeah ive thought about the gtr box, as ive driven manuals all my life! But recently ive discovered how easy autos are to drive in peak hour traffic, but they totally suck balls in the hills! So i was hoping for the compromise of auto with the ability to have some control over the shifting when i needed to! (ive never driven a tip gearbox though)
So i guess that raises the question of will a neo ecu run an s1 rb25? (nistune?)
I believe the short answer to the above is no although my mechanic is fond of saying anything is possible if you want to spend enough money. In fact I don't think the tiptronic has any more abilities in the hills than the S1 box (which I used to have before I converted it to manual). With the S1 box you can turn off the "overdrive" which leaves you the bottom three gears or if you are going downhill with a caravan or car on a trailer you can chop down to 2nd. If you also hit the snow button that cuts out 1st gear so you can pretty much control what gear you are going to use. I can't really see any value in changing to tiptronic.
^^ lol
The tiptronic box is far superior than the earlier auto.
Put a shift kit in it and it's excellent.
As for getting a Neo ECU to run a normal 25.. you would need to find out everything that is different sensor and wiring wise, and change it to suit the Neo.
OR
Just get a s2 halfcut and ditch your crappy normal 25 in favour of the Neo :P
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
