From my reading the threads over the last few weeks and elsewhere:
Royal Purple Oil would be at or near he top for racing/high perfomance driving and would tend to be changed frequently.
For Normal city Highway driving and extended oil changes BP Visco 5000 at about 60% of the price would be better/ a more sensible choice.
I will probably do 10,000km oil changes with BP Visco 10w 30w depending on the type of driving and feed back here for an M35 series 1 Stagea.
if money was no object then Amsoil would work in both situations but tends to be double the price of BP Visco 5000.
On the basis of price I wont be using Amsoil .
I realise if I use the best I will be keeping my engine in better nick but I think that has been discussed in other threads. I dont want to go down that path in this thread.
I know I wont get a definite answer but is this fairly close to correct.
Edited by samuri
gulf western s6000 sougi
group 5 ester based full synthetic which is on par with motul 300v chrono
but the GW is only $60 from a distributer (call gw to find one in your area)
check out the 'goods on oils' thread in the general maintenance section
'goods on oils' was read thoroughly but I believe a lot of responses are from those who race and use oil for extreame race condtions rather than normal driving . They then use the oil for a short duration .
I am not so concerend about getting the individusal best oil but concerned with sticking to the post topic.
This is my second attempt to attach a pole for this thread .
Off their website:
Sougi S 6000 offers:
- Full synthetic formulation providing the ultimate engine protection
- friction modified for reduced engine wear
- Proven Field performance
- Increased horse power
- Excellent shear stability performance is maintained. and very high thermal/oxidation stability provide long fluid life.
- Suitable for vehicles using Petrol, LPG and Alcohol fuels
Seems like it's fine for ethanol or Methanol...
Agreed with Scotty, the Sougi S6000 is top of the list in my books.
The car feels more "together" than any other oil I have used bar the 300v (had the same "feel") and has quick rattle on cold start unlike with Redline oil.
I tried a lot of different oils early on, but used Motul 300v or Redline for the past year and a half or so (I can't understand why anyone would skimp on oil of all things!).
I did use Amsoil 10W40 but didn't feel it was any better than Mobil 1 or Shell Helix Ultra
hmm... if you must go with Amsoil you should be able to get just under 5L of Amsoil 10W40 for around $80 or less, not a steep price to pay for a grade IV oil.... although I can't imagine why you would when you can get the Sougi S6000 (Grade V oil) for around $60.
+1 to sougi
i run it in the stagea and its my daily
dunno why you wouldn't use it, its the same price as nulon syn and lasts at least twice as long (had nulon in b4 the sougi and it got noisy at about 5000 kms)
I run Royal Purple. I know a few others do too. Aprox $100 dollars from autobarn. Doesn't have to be changed more often...Although I do a change around every 5000k.
Awsome stuff...when I put it in the Stag it ran smoother and slightly quieter.
Have a look at this artical. Its old but an interesting read.
http://www.royalpurple.com.au/article_imag..._supplement.php
I rang GW in Penrith and they want $75 for 1 bottle! Is this correct? Wondering if anyone knows of any cheaper suppliers/retailers in western Sydney, preferably Blacktown/Penrith areas
cheers
GW is in Sydney so you should be able to get it cheaper than me, I got 4 bottles for $220.
Autobarn were asking $80 a bottle.
I had to ask the guy on the phone twice, because $75 didn't sound right to me. That's directly from gulf western too. I wonder if you can buy more and get a discount?
Whilst it is a little more than what we seem to get it for in Vic... $75 for a Group V oil is bloody fantastic anyway!
Think of it this way, how would you react if you found out that your local Autobarn was selling 5L bottles of Redline 10w40 or Motul 300v Chrono at $75
EDITED :D
Edited by iamhe77
Think of it this way, how would you react if you found out that your local Autobarn was selling 5L bottles of Redline 10w40 or Motul 300v Chrono?
Mine does, but not at that price...
They didnt know what Sougi was. :D
if your getting it straight from gw then they are probably charging you rrp
check with a distributer, they should sell it to you at wholesale price, i.e. the price that autobarn etc pays for it
using either royal purple 5-30 or 10-40 .. 5 - 30 is slightly lifter knocky as its a bit too thin.
finding the 10-40 a better ratio.
although ive also used motul 300V competition .. around the same price $100 for 5 litres. and is slightly quieter on the lifters.
  • 4 months later...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
