Hel Stainless Steel Braided Clutch Line Group Buy
  • Replies 187
After one to suit R32 GTST with R33 slave
The Hel R32/R33 GTST clutch line is identical so therefore it shouldn't matter. Does that sound correct to you? What is on there at the moment?
LIST UPDATE
1. PMR33 - R33 GTST
2. 89CAL - R33 GTST
3. 33DRIVER - R33 GTST
4. MATTIS96 - R33 GTST
5. GIMPS-R34 - R34 GTT
6. DYSONEST - S13
7. JPCR33 - R33 GTST
8. GTR32R - R32 GTR
9. NA BEAST - R33 GTST
10. ADRIAN P - R33 GTST
11. MARK660 - R33 GTST
12. GOTHIK33 - R33 GTST
13. MR SCARY - R32 GTST
14. TYPEVU - R32 GTR
15. BLAGS - R33 GTST
16. SKINS - R33 GTST
17. HIBINO - R32 GTST
Edited by PM-R33
just running RB20 box and slave atm. Putting 33 box and slave in when it arrives. I assume they're the same as people just swap the slaves over. So yeah, R32 GTST one should be right.
So that's nearly 20 people, might aswell see if it gets to 30 again and I'll end it at that.
Edited by PM-R33
so ive just found this from a guy who just did a manual conversion on his stagea: "Clutch line - 650mm Long with banjo bolt on one end and jam nut on other."
he used an R34 slave and master, rs4s runs an R34/GTR pull clutch so im going to have a stab at an R34.
EDIT: i am retarded, my housemate has an R34 GTT and it only just occurred to me that i should compare them. same same.
R34 GTT please.
D.
Hahaha too easy man, cheers.
LIST UPDATE
1. PMR33 - R33 GTST
2. 89CAL - R33 GTST
6. DYSONEST - S13
8. GTR32R - R32 GTR
18. J RED33 - R33 GTST
19. OJR32 - R32 GTR
20. PINTALINE - R34 GTT
Edited by PM-R33
I wonder if nissan fast could helP with part numbers if anyone else has stagea etc problems. Couldncompare stagea lines/parts with skyline models or something? Unless the previous post has cleared that up lol
Any more takers?
If some of you guys that allready have my bank details want to start sending through the money that's cool. I'll leave the group buy still open till the end of next week like I said but i'll start PMing every one to make payments so we can get this puppy on the road.
Edited by PM-R33
Compared all 4 parts of clutch line for WC34, all parts match R34 GTT (RB25DET MT5) See attached doc for all 4 parts of hard lines for WC34 Stagea
clutch.doc
Hope this solves.
Edited by Adrian P
sweet, Nissan Fast saves the day again lol
Ill send money your way on Wednesday when I get payed Phil... Im just back from holidays so the bank account is a bit low lol
Hey Phil,
Chuck me down for an s1 r33 gts-t please mate, as per our PM convoy.
I'm skint until next Friday. Ok to pay then?
Cheers,
Aaron
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
