Hi okay let me start from the start. The oil pressure gauge on my R32 GTR always read around 4. I changed my valve covers and they are leaking oil and now my oil pressure reads just above 0. Is this related or just coincidence? Im shiting myself because i had to drive the car for a fair bit with the gauge reading between 0 and 4.
Thanks Adam
https://www.sau.com.au/forums/topic/335476-scary-oil-pressure/
  • Replies 44
no it will not cause a drop in oil pressure, oil pressure is measured inside the block oil galleries, any loss in oil after this point is not measured on the gauge but if u havent topped up the oil that u have lostt, if its alot, it will be the reason why ur oil pressure is so low as then the oil pump will be starving of oil
what is ur oil level on your dipstick with the car parked on even ground? i doubt uve leaked out that much though
it could just be a coincidence that ur oil pressure sender is dicking around - common problem
what year is ur car? the pre 1993 rb26 engines were prone to oil pump failure coz of the short oil pump drive on the crank collar
get another oil pressure gauge hooked up, dont bother with a compression test it will tell u nothing about ur current problem
head to supercheap, even a cheap arse oil pressure gauge will be fine, the porblem is trying to get the sender to fit somewhere, if you have a filter relocater this will be easy, if not its gonna be a pain in the butt
Use a mechanical gauge not electric as a poorly charge battery or low volts can make a bad reading. The stock oil gauge sender unit can be reached and replaced under the plenum just forward of and above the starter motor.
As someone said before when I first got my tomei oil pump I had the wrong spring pressure in it and I had too higher oil pressure but the stock gauge still read just bellow 4.
also is the oil pressure idiot light on?
if the guage is showing like a low reading ie 1.0kgcm2 and the idiot light is on i would say its all over
but if its only the guage that is showing low then it might not be true game over
i would certainly stop driving the car, check the basics, check oil level and check with a different guage
you're kind of right and kind of wrong there, fyi
the oil system is closed so it doesn't matter whether you take a reading on the pressure from the sensor in the block or from an aftermarket gauge that has it's sensor in an oil sandwhich plate between the block and oil filter, it should be exactly the same reading no matter where it's taken from
a leak will allow pressure to release from the whole system so it won't matter where you sensor is you will be able to see the change in pressure.
Oil pressure in my GTR sits lower than my GTS-T did under normal driving, still goes up the top when cold and when up the top of the rev range(5000+).
When Driving at 2900RPM on the highway mine sits just under the No.4 Mark.
Not sure if this is normal for GTR's or maybe has the same sort of principal as the N1 water pump that doesn't move alot of water at low speeds as it's meant for lower drag in high RPM application's.
Not sure if my car has a stock Oil Pump or of it's an upgraded unit that has a similar theory behind it.
I use Motul 300V Competition 15/50.
    • sold listed as a Tomei LSD 1.5 Way For 1998+ Nissan Skyline ER34 25GT RB25DE w/Open R200 https://www.ebay.com/itm/174006114594?campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=&mkrid=711-53200-19255-0&loc_physical_ms=108689&loc_interest_ms=&campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=71883f2ccc571356e0a757bc7adfdde2&mkrid=710-53481-19255-0&loc_physical_ms=108689&loc_interest_ms= it went in like butter all gears, alignment, back lash etc, rotation and clearances correct, and if rolling all rotates smooth and free when coasting down road , clutch in or out over 10 mph smooth... its the binding, clunking and jerking from a stop that is most concerning, also seems like its going to tear the tires off in 10 miles of normal road driving.
    • What 1.5 way? There's no such thing really as a 1.5 way, just different ways of explaining 2 ways with different ramp rates. HOWEVER. In any driving in a straight line your 1.5 or 2 or 1.7 way should have no clunking at all. With the clutch fully depressed the diff should be silent (unless it's welded but I'm assuming it's not). Something aint right here.
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
