This is something that has been bugging me for ages and I have finally had enough!
I have a 32 with a (from what I can gather) a T04e 'AIReasearch' turbo 'upgrade' and all the supporting mods (gtr pump, fuel pressure regulator, 3in exhaust off the turb0, 3.5 off the cat, and 3in intercooler piping!???).
My dilema is the car is incredibly laggy, I am talking full boost 5k. Now is this the turbo or the 3inch intercooler piping (I would have thought once the piping is filled with air it would make little difference).
I know these turbos are old and well not the best so could this be the problem? The car pulls hard all the way to rev limiter producing and really kicks you in the pants from about 5k.
If this is the problem, what is the best turbo that is reponsive down low and still pulls qute hard through the range.
Thanks in advance.
https://www.sau.com.au/forums/topic/335503-laggy-r32-gtst/
AirResearch is what Garrett was called back then, sounds like a old-school bush bearing turbo, all bush bearing turbos are incredibly laggy.. a nice new Garrett GT ballbearing turbo should make a world of difference, as for which one to choose, read the RB20/RB25 dyno thread. this thread will most likely get locked.. next time search.
https://www.sau.com.au/forums/topic/335503-laggy-r32-gtst/#findComment-5430268
rubbish the core is irrelevant, the trims and housing are the important part. The turbo in the op post is old tech trim and housing wise... slapping in a bb core wont help it 1 iota, so like i said the core is irrelevant.
Plenty of bush bearing turbo's offer awesome response.
https://www.sau.com.au/forums/topic/335503-laggy-r32-gtst/#findComment-5430354
That's right. I've got a garrett gt2876 on my rb20 and i don't see full boost until about 4500rpm and before that it's just a pig. Looks like it's time for a downsize in turbo or upsize in engine.
tdo6 20g on mine, full boost by 3200rpm doesnt compromise down low that much either best turbo choice i have seen on an rb20 and i have over 270kw atw so power is good also
https://www.sau.com.au/forums/topic/335503-laggy-r32-gtst/#findComment-5430484
..., all bush bearing turbos are incredibly laggy..
Bahah the stupidest thing ive read in a long time. Complete lies.
You obviously dont know what a Trust turbo can do.
The turbo you want is a HKS 2530. Best turbo evarrrrr for the RB20. Close to std response (use cam gears to aid response) and can make 220-230kw with fairly reasonable boost.
https://www.sau.com.au/forums/topic/335503-laggy-r32-gtst/#findComment-5430559
Either you have a TD06 on an RB25DE and you dont realise you dont have an RB20...or its a type and you meant 4200rpm...or something else is going on. I know of a few TD06 setups getting around now and there is no way on earth most people are making 16-20psi at 3,400rpm and still making 270rwkws.
Interesting for Femno and Russman to drive my car with a TD06-20G when i get back on October. The 2530 is a good thing, but i am still tempted to say the slightly laggier TD06-20G is worth living with for the wider power band and 30rwkws odd more power it can give you. I am making about 19psi at 4,400rpm or something. But really, it doesnt get its boogie on until about 4,600rpm, irrespective what the boost guage says
Bu agree with URAS, combination of wheel sizes and housings mean its probably a turbo better off an RB25, not a lower compression, shorter stroke smaller cc RB20
Edited by Roy
https://www.sau.com.au/forums/topic/335503-laggy-r32-gtst/#findComment-5430976
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
