  • Replies 210
gohan i did get your pms,sorry i been a bit busy lately....however what your asking is a only a one off job for me and i would have to charge you a large sum....i understand more people may want the products but i am really not that interested in trying to get money out of people as most people want stuff done for a bowel of rice these days!Not saying you do,just not interested in making moulds and modifying them for such a job and then trying to work them
no wuckaz, so even for 'a large sum' you wouldn't do it? could you possibly point me in the direction of someone else i may be able to talk to about what i wanted done?
anyways, all the best for the rest of the car assembling. ;)
updated pics....i ended up fitting a few extra things such electric fans,lap counter switch as per nismo MFD and an intercooler sprayer setup so i opened up the factory loom and wired it all in...it came up really well in the end,you would never know these parts are not standard.I used fans from a ford falcon controlled by a small device that taps into the vehicles original sender so no messy wiring or extra senders to fit....this unit is also adjustable in the temp department.
ok update.....Now that the mechanicals have been fitted we hang the doors,gaurds,headlights and bonnet on.We then get all the gaps right then disassemble the car again....this time we leave the door hinges on the vehicle.Then we dry rub the car with 240 grit paper taking extra care where our repairs were to shape the vehicle nicely.Then we dust the vehicle over with black dust from a 3M guide coat power sponge,this allows us to see where we are wet sanding which we do with 400 grit wet.Then the car is dryed off and wet rubbed again using 800 grit wet
i had no idea how much work goes into repairs, crazy stuff but sounds like a very high quality repair.
i didn't really want to post this in here, but it's easier for you to reply here than PM, so how's $2000 cash upfront for the body kit work? front/rear bumper? Am i ball park here $ wise? (can edit/delete this later if something is worked out, keep the thread strictly ur repair updates)
yeah, pics would be nice. wanna see all this black dust, wet sanding, 800 grit stuff. :rofl:
yeah pc is crap....will try upload some after....the first few coats of paint will be getting applied hopefully on the weekend so i will try and get some shots of it being done by one of the most talented tradesmen in the painting trade...this guy is a damn robot!!!!
you gettin sam to paint your car? thought you were gonna do it yourself?
if it is sam doin it on the weekend can i come watch n take pics? i promise i won't get in the way :)
:) for posting this thread Troy, I think its really opened people's eyes about repairs, particularly after the flack that MD took for looking at the same solution.
One of the race cars I used to run was a full cut n shut too, and it handled no worse than the other cars. I would much rather have new, straight parts than straightened old ones any day :(
Guys, you have to remember that not all shut 'n cuts are done with the same tender loving care that Troy takes in preparing his own car... Panel beaters and dodgy habibs in their backyards aren't going to undo the spot welds along the chassis rails of two cars and then seam weld them back together like you have done. They'll take two half cuts and weld them together straight across the width of the car and cover it up with underbody tar.
I don't think it's too much of a leap of faith to say that most cut 'n shut jobs are absolutely unroadworthy.
I take this type of care in preparing any car i work on.....so do all of my mates with panel shops....i do get your point but you have to understand mine....if i dint post these pics here what would you think if you heard the car was in half???you would think it was dodgy right?
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
