Ok guys I just need some opinions on what may or may not have happened to my car,
Recently (under 3 weeks) I have fully changed the exhaust which inc. a screamer and decat being 3" all the way, re-gapped my plugs to .8mm, and put an aftermarket BOV on. After having all of these on for at least over a week (except the BOV which was put on the day before) when driving my car yesterday after coming off the lights it eventually just lost power and wasn't firing properly which caused me to pull over.
After I pulled over and got to a stop it had a lot of trouble trying to idle and moved anywhere between 0rpm-1.5rpm before it eventually stalled, it done this each startup. At first I thought I had done the turbo because it was spooling all that well and there was more than enough black smoke coming out the rear!
However after I had it towed back to my mechanic because I couldnt drive it more than 2meters without it stalling. On first inspection they suspected either the turbo or some internal problem (eg: valve) but after closer inspection they put it down that my stock ecu which hasnt yet been tuned to my few mods (only couple weeks away :) ) had shat its self because it wasnt able to teach its self how to run properly with the mods, and the black smoke was a result of it running far to much fuel than it needed.
I'm just wondering what some peoples thoughts are on this problem and whether my mechanic is right (im a bit hesitant to believe that just a tune will fix it because they have never really worked with turbos before) ? Please make it good news :)
Cheers,
Dallas
https://www.sau.com.au/forums/topic/337156-skyline-stop-running/
  • Replies 46
Cheers,
Dallas
Your ecu is not tunable. Do a search for the alternatives. Stick your stock bov back on.
As everyone has said the BOV is almost certainly causing the air flow readings to get stuffed up take it off or at least block it off. Also take it to a proper performance mechanic that has experience with similar cars next time, will save a lot of time wasted on diagnostics that someone who has seen the problems before will pick up immediately
Correct, you can't vent air (BOV) to the atmosphere with AFMs without a tune to suit as it needs to be tuned out. MAF sensors measure the air as it comes in, the stock ECU is expecting that ammount of air to arrive in the intake manifold, the stock BOV works by recirculating the air back into the air intake. What you have done is starve your engine of air.
all stock apart from the parts stated earlier (exhaust, POD, regap plugs, BOV).. Im putting down to the BOV atm, will turn it back to plumb back and have a go at reseting the ecu tonight..
plugs not issue
zorst not issue
ecu not the issue, and wont shit itself with diff mods, it isnt tunable
bov is the issue
ur car wouldnt react so badly if it was rich, it would just run really rich and slower with black smoke
Just went and fiddled with my car again today after finally finishing all my drinking for the grand final weekend :) lol..
Tried resetting the ECU by removing the neg terminal and pumping the brakes , lights etc until all power was gone (after turning the BOV back to plumb back) , hooked the battery back up and started.. At first it seemed ok and was idling fine until after a couple of short revs where it started to range over 1000rpm differences. So it obviously hasnt worked yet but I plan to go back tomorrow and put the stock BOV back on and try the same again to see if that has an effect :S ..
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
